2001 SLS Suspension to High
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, 2001 SLS Suspension to High in Item Specific Cadillac Discussion; Had the tires changed couple of weeks ago and after that I noticed the rearend being to high off the ...
    qa2155 is offline Cadillac Owners Member
    Mar 2006
    Had the tires changed couple of weeks ago and after that I noticed the rearend being to high off the ground. Read in the forum earlier on that I need to deflate the system. Well I have done that and it was fine for a couple of days and now it's back up there again. looked at the the leveler under the car and the rod is not bent that attaches to the rear control arm. There are no codes from the computer either. Any suggestion on what can be causing it to constantly inflate?
    Sep 2003
    Metro ATL
    4,854
    Re: 2001 SLS Suspension to High
    Sounds like the exhaust valve on the compressor is not doing its thing. And that should set a DTC or two.
