Ceramic Brake Pads '02 SLS???
Results 1 to 5 of 5
Suspension, Brakes and Tires Discussion, Ceramic Brake Pads '02 SLS??? in Item Specific Cadillac Discussion; Gentlemen, I'm getting ready to replace my rotors and brakes. I ordered the cross drilled and diamond slotted rotors yesterday ...
    sjpi1954's Avatar
    sjpi1954 is offline Cadillac Owners Member
    Automobile(s): None
    Oct 2005
    Pensacola
    62
    49
    Gentlemen,
    I'm getting ready to replace my rotors and brakes. I ordered the cross drilled and diamond slotted rotors yesterday and have held off on the brake pads. I opted not to buy the bottom of the line rotors on eBay but I also opted not to spring for the Brembos...hey, I bought the Cadillac for everything but street racing.
    State of the art pads are now ceramic blends. Beneath that are the Kevlar/Metallic/Organic Blends. OEM are the semi-metallic with the rear pads having the sensors on the '02s. Bottom of the line stuff is still organic pads.
    Does anyone have any experience with the ceramic pads? IF so, do you have a brand specific recommendation. I also wanted to see if anyone has changed their calipers and lines and if so did you go with OEMs or aftermarket kits.
    Thanks,
    JP
    Never give up, Never surrender
    sjpi1954's Avatar
    Automobile(s): None
    Oct 2005
    Pensacola
    62
    49
    Re: Ceramic Brake Pads '02 SLS???
    Gentlemen,
    Found three other references to EBC pads in the Forum so disregard. Nothing is available locally so I'll have to order. Thanks for the views. This thread is dead.
    JP
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,661
    so you ended up getting the EBC pads?
    tstach is offline Cadillac Owners Fanatic
    Automobile(s): 2001 BMW M5 - Alpine White
    Jul 2003
    Hebron, KY
    52
    226
    I'm running the EBC sport rotors with AC Delco Dura Stop ceramic pads on the front. In my opinion, they work so much better than the OEM setup. Shorter stops, no brake dust and no fade. My rear EBC rotors just came in today and I will be doing the rears with these and the Dura Stop pads to match the front.
    Keep in mind that the EBC pads do not have the notched out area for the pad wear sensor, so if you plan to continue using the sensors (as I have), you'll need to look at AC Delco or possibly Raybestos.
    69
    82,171
    Quote Originally Posted by sjpi1954
    The fronts have sensors as well.
  8. Remove Advertisements
