wheel cylinder blowing
Results 1 to 8 of 8
Suspension, Brakes and Tires Discussion, wheel cylinder blowing in Item Specific Cadillac Discussion; Hey Folks I replaced the shoes and wheel cylinders on my 87 Brougham. The drivers side rear cylinder keeps popping ...
    johndfw's Avatar
    johndfw is offline Cadillac Owners Fanatic
    Sep 2005
    Arlington Texas
    52
    201
    Hey Folks
    I replaced the shoes and wheel cylinders on my 87 Brougham. The drivers side rear cylinder keeps popping appart. Two times now. The first time I was able to reassymbal it, this time the rubber boot was destroyed.
    Has this ever happened to anyone ealse?
    Later
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Re: wheel cylinder blowing
    It may be time for a new proportioning valve.
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    That's a new one. Even cars without the valve don't "pop". Did they give you the right parts? Are the shoes/hardware assembled correctly? The left and right should look like mirror images.
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Have pictures? The spring tension on the shoes should hold it together if nothing else. The drum would keep it from overextending when applied.Maybe something isn't quite lined up right?
    Krashed989's Avatar
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Are you bleeding it before putting everything back together?
    If so, you should put it all back together first (with a new cylender), then bleed it.
    johndfw's Avatar
    Sep 2005
    Arlington Texas
    52
    201
    Hey Folks
    I think what happened was one of the steel plungers, sorta shaped like a bolt with two slots on the head, was installed wrong. Mechanic error,not mechanical error. I must have goofed from being in a hurry.
    Thanks for your thoughts.
    Later
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    If those have the 4 little tabs on the pins that go into the shoes on the grooves, you have to be careful to make sure they mate properly with the shoe. If they are not in place, they will shoot right out when you step on the brake. It's hard to line all that stuff up when you assemble it.
    There is no other way that can happen though. I hate to say it but it has to be the way you put it together.
    johndfw's Avatar
    Sep 2005
    Arlington Texas
    52
    201
    Yeah..........Thats what I thought.
  11. Remove Advertisements
