20" rims on a 84 needs better brakes???
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, 20" rims on a 84 needs better brakes??? in Item Specific Cadillac Discussion; i have a 84 eldo and im planning on putting 20's on it but i have read everywhere if you ...
    CaddyFromNowOn is offline Cadillac Owners Member
    Jan 2005
    8
    i have a 84 eldo and im planning on putting 20's on it but i have read everywhere if you increase the rim size you sould upgrade the brakes anyone know where i can get a upgrade for this car??
    durrk's Avatar
    durrk is offline Cadillac Owners Fanatic
    Jan 2006
    Milwaukee, WI
    31
    116
    Re: 20" rims on a 84 needs better brakes???
    hello, Id also like to know if this has to be done, as I am also looking for some rims.
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,661
    If you can find wheels that are strong enough, yet fairly light, you wont need to worry about it.. I would suspect OEM wheels weigh anywhere from 15-20lbs... If you want some bling bling 20in Chrome wheels id say youd be looking at 25+ lbs... Whenever you increase wheel weight by 10lbs, its similar to adding 40lbs of static mass to the car..... So if each wheel is 10lbs heavier, you have 4 wheels, thats like adding 160lbs of extra weight to the car... IE another person, give or take..
    the short answer is, if your brake system is in decent shape as is, i wouldnt worry about it. If oyu are concerned about it, get some new rotors and good pads, and then go from there.....
