1993 CdeVlle front suspension all the way up
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, 1993 CdeVlle front suspension all the way up in Item Specific Cadillac Discussion; My 1993 coupe de Ville w/air-suspension. The air pump runs for a while after the engine is shut off; and ...
    flyboyaviator is offline Cadillac Owners Member
    Jan 2006
    6
    My 1993 coupe de Ville w/air-suspension. The air pump runs for a while after the engine is shut off; and the front suspension is all the way up does not come down after the key is out of the ignition? Any ideas? thanks.
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Re: 1993 CdeVlle front suspension all the way up
    The FRONT? Thats a new one. Your car only has the load leveling air suspension in the back. That is, unless you bagged your car. Can you find one to compare with, maybe its more along the lines of the rear sagging...
    Jan 2006
    6
    DAvid;I'm going to compare with other Caddy,but yes,the front suspension did go up and then go down after eng shut off, now is up.
