S061-Troubleshooting
Results 1 to 4 of 4
Suspension, Brakes and Tires Discussion, S061-Troubleshooting in Item Specific Cadillac Discussion; I got the intermittent S061 code which is the right front position sensor. Can I take this sensor and switch ...
    51magnum is offline Cadillac Owners Member
    Jul 2003
    Boise, ID
    45
    I got the intermittent S061 code which is the right front position sensor. Can I take this sensor and switch it with the left front and see if the problem follows the sensor. That would tell me if it was the sensor or the wiring. I am just unsure if the sensors can be swapped.
    Thanks
    Goodyr is offline Cadillac Owners Fanatic
    Automobile(s): 94 Seville 2006 STS
    Jan 2004
    Cincinnati, Ohio
    149
    Re: S061-Troubleshooting
    I have posted about this sensor. I don't know if you can switch them. Mine started off intermittent and then come everytime I started the car. About $384.00 from the dealer and around $200.00 from gmparts direct. My mechanic got me one from the junkyard and it has been on for about 4 months. The message has not come up since. He charged me $100.00 for the part and putting it in. Took him about 15 minutes. He put it on the lift and never had to remove the tire. I stopped working on cars 25 years ago. I hope this helps in some way.
    Ralph
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Yes, you can switch them. In fact ALL 4 of them are interchangable with eachother.
    Jul 2003
    Boise, ID
    45
    Thanks, I will try this out and post what I find.
    Shane
  7. Remove Advertisements
