How To: Change Rear Brake Pads & Rotors, Documented - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Suspension, Brakes and Tires Discussion, How To: Change Rear Brake Pads & Rotors, Documented in Item Specific Cadillac Discussion; Evenin' from Pensacola Mark, I just wanted to sincerely thank you for your post and pictures. I just finished the ...
  1. #16
    sjpi1954's Avatar
    sjpi1954 is offline Cadillac Owners Member
    Automobile(s): None
    Oct 2005
    Pensacola
    62
    49
    Re: How To: Change Rear Brake Pads & Rotors, Documented
    I just wanted to sincerely thank you for your post and pictures. I just finished the front rotors and pads and am getting ready to tackle the rear. Wanted to re-read your post to make sure so once again...thanks.
    Never give up, Never surrender
    JP
  2. #17
    sjpi1954's Avatar
    Automobile(s): None
    Oct 2005
    Pensacola
    62
    49
    Gentlemen,
    I wanted to pass on a Tech Tip for those of you changing all 4 rotors, pads, and fluid. 3 of my rotors came off without so much as a light pull. However, my right front rotor was literally rusted to the hub spindle. It would NOT budge and lightly tapping against a piece of 1x4 with a mallet at different spots on the backside made no difference.
    IF you have a stuck rotor try this....Get on your back, looking at the backside of the rotor, while holding a can of WD40 with the red hose nozzle attached. I used my hunting LED headlamp to free up my other hand to rotate the rotor while spraying with the right hand. On the back side of the rotor there is a gap, about .5mm, in between the rotor and the spindle. That small gap is your aim point.
    Put the nozzle into that gap, spray, rotate rotor 90 degrees, spray again, repeat until 360 degrees of coverage. Take a break for at least 10-15 minutes.
    When I came back I was able to immediately pull the rotor off. The inside/backside of the rotor where it flushes up against the spindle looked awful...mucho rust.
    Clean up your spindle and the rest of the mess and get back to work.
    I just got back from completing the 'Burnishing Procedure' and what a smooth, powerful, comfortable difference new rotors, pads, and fluid can make.
    JP
  3. #18
    sjpi1954's Avatar
    Automobile(s): None
    Oct 2005
    Pensacola
    62
    49
    Gentlemen,
    Just finished all 4 cross drilled and slotted rotors, Hawk Performance Street Pads, 100% new brake fluid (Dadillac's sage advice) with a 13 year old to pump my pedal. The difference in this '02 SLS with a refurbished and upgraded brake system is simply astonishing.
    We all know how powerful the N* is under any Cadillac hood, but the stopping power of a completely new and upgraded brake system totally compliments this car. The final numbers were interesting...Cadillac OEM Rotors and Pads $550 plus tax. Custom cross drilled/slotted rotors, Hawk HPS pads, Quart of Prestone DOT 3 $325.
    Longevity on the non-OEM rotors and pads remains to be seen.
    The more I drive my Seville the more I regret not getting a Cadillac 30 years ago...what a car.
    JP
  5. #19
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    JP, were you able to keep the pad sensors? Let us know how the job works out. Some people complain about warped rotors, squeeling etc after a while. I need to do my fronts soon. My calipers and rotors look rusty thru the rims.
  6. #20
    GTX
    GTX is offline Cadillac Owners Member
    Jan 2004
    17
    Nice Write up ! Thank you !
    What happened to the pictures
  7. #21
    Just_me is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2006
    10
    Hey guys,
    Can anyone help me out with the password that prompts you when clicking on the site: Complete set of pictures are here: http://gallery.iametarq.com/photos/c...%20sls/brakes/
    (at the top of this page).
    Also, can't seem to see the pictures on this page for replacing brakes. Is that just my computer or they really not there? Thanks again!
  8. #22
    mlcarey1959 is offline Cadillac Owners Member
    Automobile(s): NONE
    Jun 2012
    1
    Where are the pictures?
  9. #23
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,919
    It's a 5 year old dead thread - Tarq may have taken down the gallery to decrease his attachment load - we're allowed only 20 mb of attachment space, so we all purge old thread stuff now and then.
    If you have a Cadillac and it's close to the year group the OP did the work on, there will be more info found in Discussions, Item Specific: Cadillac Tech Tips, or Google something like "cadillac forums seville rear brake pads" or "cadillac forums seville brake caliper replacement".
  10. #24
    slawolom is offline Cadillac Owners Member
    Automobile(s): Deville 2004
    Jan 2013
    9
    Can someone update pictures for brake replacement?
    The ones here are expired
  11. #25
    Jesda's Avatar
    Jesda is offline Super Moderator
    Automobile(s): 2002 Seville STS F55, 2006 Mazda Miata
    Sep 2003
    DETROIT
    35
    22,374
    Very similar if not identical steps:
  12. Remove Advertisements
