95 deville riding low in the back, "service ride control"
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Suspension, Brakes and Tires Discussion, 95 deville riding low in the back, "service ride control" in Item Specific Cadillac Discussion; ok guys here it is, i bought the car for $1300 with 150,000 about a month ago (last owners were ...
    yafuturehubbie is offline Cadillac Owners Member
    Nov 2005
    queenz NY
    35
    Cool95 deville riding low in the back, "service ride control"
    ok guys here it is, i bought the car for $1300 with 150,000 about a month ago (last owners were pigs), and i dont know much about caddy's but i do like them, anyways the problem i have is its throwing up the "service ride control" , now my friend had taken off the left rear wheel and said he had seen the strut leaking meaning i have to change it, problem is i honestly dont want to pay 500-700 for the rear struts, so what do i do ?
    by the way i checked for codes and the code its throwing up is the io39 : Loss of Road Sensing Suspension Data
    how do i fix it and how much am i going to be spending to fix it ?
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: 95 deville riding low in the back, "service ride control"
    The best thing to do with that many miles is to replace the struts and rear air shocks with passive, non-electric controlled ones. It will run you around $400 or so for all 4, but will get rid of any future electronic ride control problems.
    There is a relay available from GM that gets rid of the "Service Ride Control" message, and only costs around $35. I used to have a 94 Deville Concours and it seemed like I was always throwing $200 suspension sensors at it, and never got rid of the message! I now have a '94 Deville, and I have installed passive struts and shocks along with the relay I mentioned, and it rides great!
    Stoneage_Caddy's Avatar
    Stoneage_Caddy is offline Cadillac Owners 10000+ Posts
    Automobile(s): 01 frontier , 89 Shelby CSX vnt
    May 2003
    Undisclosed location in FL
    14,607
    check the compressor too , flip they key to the "run" position so the dash comes on (dont start the engine)....have someone standing at the back of the car and have them listen for the compressor to kick on (sounds like a farting noise), should happen within 30 seconds of the key being turned to run , the compressor should run for around 3-10 seconds....if you never hear the compressor youll need to check the fuses
    IO39 covers alot of diffrent problems ....and sometime the relay wont get rid of the code ...in my case i had to override a option setting
    Nov 2005
    queenz NY
    35
    yea im going to check the compressor because i honestly doubt it is turning on, but where would the fuses be for the compressor , in the rear or the front ?
    and for the passive, non electronic shocks what name brand did you use or do people usually recommend?
    Nov 2005
    queenz NY
    35
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    The fuse is in the trunk, on the drivers side. I've used Arnott and Strutmasters for shocks and struts, but some people have had bad service from some of the companies.
    Nov 2005
    queenz NY
    35
    any suggestions on monroe? because in pep boys the passive ones are 59.99 each , oh and by the way i checked the compressor and it turns on , but nothing happens..
    Nov 2005
    queenz NY
    35
    May 2003
    14,607
    monroe has always been a good shock ...
    Nov 2005
    queenz NY
    35
    lol ok so now the question stands at should i pay 120 for each with the sensors on them or 60 for each for the passive ones?
    May 2003
    14,607
    id go passive for sure .....in fact i did
    AdnanBomova's Avatar
    AdnanBomova is offline Cadillac Owners Fanatic
    Dec 2005
    freehold, nj
    30
    115
    wait wait wait, they sell passive sturts at pep boys for 120/60 bucks each? are u serious?
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Yeah, where are you finding electronic struts THAT cheap???
  16. #14
    May 2003
    14,607
    were talking rears here , not front .....at leat i hope so ...id be pissed if i coulda gotten the fronts that cheap
  17. #15
    Nov 2005
    queenz NY
    35
    yea the rear struts, for a 95 deville 120 with the sensor and 60 without
  18. Remove Advertisements
