Results 1 to 4 of 4
Thread: 1979 disc brakes
    oyoung is offline Cadillac Owners Member
    Automobile(s): 1979 sdv
    Oct 2005
    MS
    27
    1979 disc brakes
    Hello: I a week ago purchased for 385.00 a 1979 sedan deville runs good trans slips a bit no rust no dents seats and dash cracked.Today I discovered that this car has rear disc brakes,I like,but how can that be?
    Thanks
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: 1979 disc brakes
    Congratulations. Some cars have rear disc brakes, that's how it can be. I don't see them listed as an option but the list I'm looking at could be incomplete. Alternatively it could have a Fleetwood parts back there.
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,531
    I have always heard about them, but never actually seen them. They are related to the 76-78 Eldo rear disc, (same rotors, backing plates and calipers), which is very similar to the 79-81 rear disc on the F Bodies (Pontiac carline), which used 2" pistons in the calipers and mounted one front and one rear (to clear the shocks), as opposed to the B/D/E body 2 3/8" larger caliper pistons. They were common to have the e brake actuator problems (mainly because people didn't use it) and often when people were changing brake pads, they would break the bolt trying to retract the piston into the bore.
    The 79-81 F body, 79-85 E, and the 76 E, 77-79 B/D body cars shared rotors with the E/D bodies having the 5x5 bolt pattern vs the 5x4.75" pattern.
    The 79-85 E Bodies and 79-81 F Bodies shared calipers and rotors. Not sure on backing plates, but possible.
    Front calipers work on the rear, but lack e brake provisions, and are the larger pistons. Which is a safety issue.
  5. #4
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Yeah, my '76 Eldorado has rear disc brakes. You're dealing with Cadillacs now, better get used to this kind of thing
  • You may not post replies
