Go Back   Cadillac Owners Group > General Discussion > General Cadillac Discussion > Suspension, Brakes and Tires
Suspension, Brakes and Tires Discussions relating to improving the handling, ride and stopping-power of your Cadillac.
Cadillac Forums: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message
  #106 (permalink)
Old 02-12-06, 06:16 PM
Stoneage_Caddy's Avatar
Cadillac Owners 10000+ Posts
Cadillac(s): 94 Deville 4.9 (Gladys),2006 H-D 883-R (Midnight Rider)
View Stoneage_Caddy's Photo Album
Casino Cash: $5520
Re: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message
im trying to find it ...alot of the stuff is missing right now
basicly a relay is wired into ckt 370 red at the module in the trunk ...with the key on the relay is energized and one side of the circuit is grounded ....you may also need to adjust the iso8 setting int he ipc overirides like i had to ....
all the info is here somewhere on my computer ....problem is i got a new computer since i had been thru this so its in a file on this computer marked "Dell" ....itll take some digging
  #107 (permalink)
Old 02-14-06, 10:32 PM
tux tux is offline
View tux's Photo Album
Casino Cash: $250
I have a 94 Eldorado w/ the Northstar, and get the same message. How do I check the ride control box? It said in earlier post to ground the "c" pin, to be fair i havent looked at it yet to know but is "c" labeld on the module?
  #108 (permalink)
Old 02-18-06, 02:12 AM
View LChrisNS's Photo Album
Casino Cash: $250
I have just purchased a 1991 Deville with 75k. All is good except the rear struts are fully inflated which causes the rear to ride high. Can someone please advvise what I should do or check for?
Thanks,
Chris
  #109 (permalink)
Old 03-11-06, 12:27 PM
View Caddwull's Photo Album
Casino Cash: $250
I've got a problem I hope someone can give guidance on. I have a 95 Concourse and just went to passive struts on the front. The shop who did the work installed the resistor that came withe the shocks and now I get the "Service Ride Control" message after a couple miles of driving. It will go away if the car is turned off, but will then return after a few miles of driving.
Does any one know of a way to eliminate this?
  #110 (permalink)
Old 03-15-06, 06:45 AM
Cadillac(s): 82 fleetwood - 97 deville
View fubar569's Photo Album
Casino Cash: $3447
your problem is that it's seeing data from 2 corners and 2 are dead
you should have resistors at all 4 corners. that will eliminate your light
  #111 (permalink)
Old 03-29-06, 10:36 AM
Rob_M's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 99 Cadillac STS
View Rob_M's Photo Album
Casino Cash: $670
I just fixed my SRC message. I ran the codes and got S061 and S063. I ordered 2 height control sensors from a junkyard, snapped them in and no more problems. I just thought you'd like to know that before you do the disable proceedure. They were fairly easy to put in. Just gotta use your noggin! In the case that I might need new struts, I would consider the passives and do the message disable proceedure. If it could be fixed for $150 like mine, I'd rather have the electronically controlled ride.
  #112 (permalink)
Old 04-02-06, 07:10 PM
View G_sts's Photo Album
Casino Cash: $250
Hey Guys I have a 97 sts ...for the longest time ..When I would hit a bump my stability warning would come on and my abs and trac contor lights would come on the dash ......So I went and looked at the front end conections from the speed sensor ...now the warning lights will not go off ....so I checked the speed sensors with a ohme metter and the are ok ...But when I read the codes it is telling me that my letf front and right rear is not working ...Now my question is are they both on the same circut ? any help on this would be great cause it's driving me nuts
  #113 (permalink)
Old 05-19-06, 01:24 PM
Cadillac(s): 1995 Deville
View ogbuehi's Photo Album
Casino Cash: $435
This thread is insane. It's dedicated to fixing the common Service ride control message but there isn't a single clear cut post on how to do this. Some say do a resistor thing, others say swap out struts. I want to change out my struts but the closest cadillac dealership doesn't do it anymore. I don't have enough skill to rip apart this and that and be able to put it back together again. Does anybody know a reliable suspension person in the D.C. area that knows how to do this?
  #114 (permalink)
Old 06-06-06, 02:32 PM
Cadillac(s): STS 1994
View jackswe's Photo Album
Casino Cash: $275
Thumbs down Re: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message
I also have that "service ride control" on my display.
I have a Cadillac STS 1994 with Northstar 4,6 L engine
Original, but Europe sold so I have km/h instead of miles
and Celsius instead of Farenheit. I guess/think but I'm not shure,
that those cars that were shipped to Europe had harder suspension
springs ???
If I press "red" (warm) button and "off" buttom I have these codes:
P052 HISTORY
P061 HISTORY
P062 HISTORY
P071 HISTORY
P091 HISTORY
P109 HISTORY
NO IPC CODES
NO ACP CODES
NO SIR CODES
T072 HISTORY
T073 HISTORY
S015 HISTORY
S016 HISTORY
S018 HISTORY
S036 HISTORY
S044 HISTORY
S061 HISTORY
What does all these codes have the word histroy behind ?
What does all these codes mean ?
Is it good or bad to not have any codes on IPC, ACP and SIR ?
Looking forward to solve this. Thanks for the time you lay down trying to help me (and others with same codes).
  #115 (permalink)
Old 06-12-06, 10:45 AM
View jztw36's Photo Album
Casino Cash: $250
The "http://caddyinfo.netgetgoing.com/disable.htm" you referance above, I can not get to, site not found. Has it moved, could you update us please, I have the same situation on my caddy... THANKS.........
  #116 (permalink)
Old 06-26-06, 10:11 AM
View Soxxman's Photo Album
Casino Cash: $250
It sounds like I have the same issue you have with my ’94 Sedan DeVille. When checking my code it also read Code IO39. When I took it to the dealership they said I needed all 4 struts & shocks replaced and a relay. I am getting the Service Ride Control Alert, and when I drive over 15 miles per hours I hear a noise on the left front of the car that tends to get louder when I turn or the car shifts. It is a dull groan. Does this sound like a similar description of your problem? And what did you finally find out?
  #117 (permalink)
Old 06-26-06, 10:14 AM
Casino Cash: $250
What symptoms were you experiencing & what year & model is yours?
  #118 (permalink)
Old 08-07-06, 01:03 PM
newetc's Avatar
Cadillac(s): Eldo
View newetc's Photo Album
Casino Cash: $875
I have a 96 eldo with 70k and been seeing this message for a while now.. it seems to come up when i take off fast and sudden braking.. i guess the suspension is getting softer as well.
I think i'm just going to replace the suspension and by-pass the signal..
I know there is a how-to but the links are no longer good since this thread was started in 2003.. maybe someone can post up some updated info.
If i find some info that is updated i'll post back.
Thank you.
  #119 (permalink)
Old 08-30-06, 04:36 AM
Krashed989's Avatar
Cadillac(s): 94 Eldorado, and a totaled z rated STS
View Krashed989's Photo Album
Casino Cash: $10908
Thank you.
Check the codes before doing anything.
  #120 (permalink)
Old 10-24-06, 09:18 AM
Cadillac(s): '94 STS, '94 SLS, '72 couple deville
View Reactor's Photo Album
Casino Cash: $250
Wink Re: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message
If anybody is still wanting to know,
On a '94 4.6L Seville, with 2 wires on the struts, a fuel injector wired inplace of the strut wiring will fool the computer, the "Service Ride Control "goes away.
I personnelly did it last night and it works.
FYI
Tags: , , , , , ,
message, sensitive, service ride control, speed, suspension
