| Suspension, Brakes and Tires Discussions relating to improving the handling, ride and stopping-power of your Cadillac. | Cadillac Forums: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message
02-25-04, 03:34 PM
|  | Cadillac Owners Enthusiast | | Join Date: Feb 2004 Location: Staten Island, NY | | | Re: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message I retyped from hard copies, created 3 pdf file with scheme and trouble tree (for code S061). I can send it to mail address (I just don't know how to post these files on the forum).
I tried to create files as close as possible to the originals. |
02-25-04, 03:38 PM
|  | Cadillac Owners 10000+ Posts Cadillac(s): 94 Deville 4.9 (Gladys),2006 H-D 883-R (Midnight Rider) | | Join Date: May 2003 Location: Undisclosed Location (cave) Fl | | | Re: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message DUDE! your the man ...ill send you a pm with my e mail info |
02-25-04, 06:00 PM
| | Cadillac Owners Member | | | | | Re: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message Great! I will also PM you with my info. Thanks for thinking of us. |
02-26-04, 09:44 AM
|  | Cadillac Owners Enthusiast | | Join Date: Feb 2004 Location: Staten Island, NY | | | Re: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message |
02-29-04, 07:53 PM
| | Cadillac Owners Member | | Join Date: Feb 2004 Age: 25 | | | Re: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message I have the same problem as you guys and it feels to me like my struts are ALWAYS soft anyway I can force them to stay FIRM and then just disable the "service ride control" read out like in the above post? |
03-04-04, 08:42 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2003 Cadillac DeVille | | Join Date: Jun 2003 Location: Ontario, Canada Age: 24 | | | Re: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message CONSIDER MYSELF SIGNED ON.
I also have a 94 DeVille, with the same problem, but I am not satisfied with the solution of the system bypass. |
03-05-04, 12:54 AM
|  | Cadillac Owners 10000+ Posts Cadillac(s): 94 Deville 4.9 (Gladys),2006 H-D 883-R (Midnight Rider) | | Join Date: May 2003 Location: Undisclosed Location (cave) Fl | | | Re: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message where you been dfx? |
03-05-04, 12:59 AM
|  | Cadillac Owners Fanatic Cadillac(s): 2003 Cadillac DeVille | | Join Date: Jun 2003 Location: Ontario, Canada Age: 24 | | | Re: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message Quote: |
Originally Posted by Stoneage_Caddy where you been dfx? | I left this community when I realized I had no chance of becoming a mod here...and when people without even 20 posts were being promoted first.
I said forget it, and headed to greener pastures so to speak. |
03-05-04, 12:57 PM
|  | Cadillac Owners 10000+ Posts Cadillac(s): 94 Deville 4.9 (Gladys),2006 H-D 883-R (Midnight Rider) | | Join Date: May 2003 Location: Undisclosed Location (cave) Fl | | | Re: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message i see , i hear you on the mod bit , dont feel bad i havent been tagged for duty either....i have my notions on how people become a mod but im not gonna go there
i usuly voulnteer in every forum to be a mod to "help out" , not once have i heard anything back (i think ive been on 6 or 7 forums now with a combined 3000 posts)... i guess it has something to do with how people say "i keep it real" |
03-08-04, 10:57 PM
|  | Cadillac Owners Member | | Join Date: Mar 2004 Location: NY, NY Age: 30 | | | Re: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message WAS INCORRECT ON MY ORIGINAL POST I EDITED AND FIXED THE TERMINAL LOCATIONS
I have the same problem with a Service SSS light also on my Cadillac. I work at a mechanic shop and have access to the all data mechanic aid program, and let me say its a big help. If you have a paper clip you can read the diagnostic code numbers and if you want I will look them up and give you the diagnostic procedure you can use. Take the paper clip and make it in the shape of a U. Then under the middle of your front passenger compartment under the radio by where your feet go you will see a large 12 pin connector. I know its on the LEFT side of the connector, TOWARD THE DRIVER'S SIDE, but i'm not sure if its the top or the bottom portion since its pretty much like this
.OOOOOO
.OOOOOO
but you have to stick the paper clip in either these two holes (marked as x's)
......|...... <-- that is the top marker tab for connector position
.OOOXOX
.OOOOOO
BE CAREFUL CAUSE WHEN YOU LOOK AT THE CONNECTOR ITS UPSIDE DOWN
SO POSITION THE PAPER ACCORDINGLY TO MATCH UP
Its pins A and C according to the ALL data Program if that helps
Now you turn the key to the on position (with out starting) all the dashboard lights will display including the service sss light. you know you picked the right pins when after the light goes out it begins to flash
it will flash once then pause a second and then flash twice together (this signifies a #12 code which means it is entering diagnostic) three times before displaying the actual trouble code. So you pretty much understand how you would read the codes after the three 12's that will flash out.. then you will get the codes listed. I got a code 24 on my car 2 quick flashes one second pause then 4 quick flashes. It will do each code three times before displaying the next. When it does the 12 code again that means it finished the code list and will start again.
email me at dzisblatt@si.rr.com and I would be glad to help in any way I can
03-12-04, 11:22 PM
Originally Posted by Coupe WAS INCORRECT ON MY ORIGINAL POST I EDITED AND FIXED THE TERMINAL LOCATIONS
.OOOOOO
.OOOOOO
.OOOXOX
.OOOOOO
email me at dzisblatt@si.rr.com and I would be glad to help in any way I can  | The problem with this procedure is that it only works on 93 and lower caddies. That's why they created the new IPC with the OBD system in the IPC, so you don't have to short anything and read the codes off the dash. |
03-13-04, 05:01 PM
|  | Cadillac Owners Member | | Join Date: Mar 2004 Location: NY, NY Age: 30 | | | Re: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message Ya if you guys have newer ones. However, even the 92 sevilles have the new IPC. Press and hold the off and warmer buttons on the climate control to read codes off of it. I believe the "I" codes are the suspension ones. If they don't list then you have to use the conventional method I posted before. Sorry man you are right  |
03-13-04, 08:19 PM
Originally Posted by Coupe Ya if you guys have newer ones. However, even the 92 sevilles have the new IPC. Press and hold the off and warmer buttons on the climate control to read codes off of it. I believe the "I" codes are the suspension ones. If they don't list then you have to use the conventional method I posted before. Sorry man you are right  | The I codes are IPC/Electronic computer related. 'S' codes are specfically related to suspension.
IE - I039 = Loss of RSS Data possibly meaning the ESC module has gone kaput. |
03-16-04, 12:26 AM
|  | Cadillac Owners 10000+ Posts Cadillac(s): 94 Deville 4.9 (Gladys),2006 H-D 883-R (Midnight Rider) | | Join Date: May 2003 Location: Undisclosed Location (cave) Fl | | | Re: Speed Sensitive Suspension and the "SERVICE RIDE CONTROL" message "ESC module has gone kaput."
or at least thats the current theroy , im gonna locate a good one to install before my rss amputition
or do you know something i dont ? if so im all ears (or eyes in this case)
unforetunalty im thinking i will need struts , im getting a wicked rebound lately |
03-17-04, 12:12 AM
unforetunalty im thinking i will need struts , im getting a wicked rebound lately | The ride on mine is far too bouncy as I noted awhile back saying I could do fake hydraulics just by hammering the brake.
My father and I have agreed upon replacing the now dead GM sturts with some top of the line Monroe ones that will essentially turn the thing into the handling of the STS. No more bounce, but quite frankly stoneage i'm sick of the body roll when turning corners or when the nose dips when I brake or when it bottoms out when going over speedbumps.
Frankly I think this I039 bullshit is purely electronics - ESC module or related connectors and/or wiring. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
