"1991" DeVille Brake problem
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, "1991" DeVille Brake problem in Item Specific Cadillac Discussion; I have a 1991 DeVille that is in great condition. Bought the car several years ago and at that time ...
    RoofMan is offline Cadillac Owners Member
    Nov 2004
    33
    I have a 1991 DeVille that is in great condition. Bought the car several years ago and at that time done a complete brake job on the car. Recently I have had a problem with the brakes. The brake pedal will travel to the floor and they feel soft/spongy. You can pump them up to stop the car but the next time you apply them they are right back to soft and traveling to the floor. I changed the mastercylinder and bleed them but with no inprovement. I bleed the brakes after driving for a while and got more air from the line but still no luck. Can someone please tell me what else I can look for or do to repair this problem? Tahnk You!
    Noya is offline Cadillac Owners Member
    Jan 2005
    9
    Re: "1991" DeVille Brake problem
    I had the same problem on my Eclipse GSX, but the master cylinder solved it. I recall I had to bleed the master cylinder and then the brakes. If you've done both correctly your evidently losing the pressure somewhere. A leak maybe? Are you checking the reservior for loss? What about the brake booster?
