98 Eldorado Stability Ride
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, 98 Eldorado Stability Ride in Item Specific Cadillac Discussion; My name is Sean and i bought a 98 Eldorado and it turns out it has some problems..... im sure ...
    ImOldSkoolz is offline Cadillac Owners Member
    Nov 2003
    Louisville Ky
    48
    1
    Angry98 Eldorado Stability Ride
    im sure my problem is something i have done ...as i have altered the Car..
    I bought a new sound system that put extra wieght in the trunk so now the car rides lower in the back so i then bought Eibach Lowering springs for the front ....the car now sits level.....but when i go around corners the Stability Ride System always turns on cause the car to neary shut down.....is there anyway i can turn this feature off and if so HOW.....its driving me nuts and its gonna cause me to wreck on off ramps in rush hour
    Thanks in advanced
    Sean
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,661
    Re: 98 Eldorado Stability Ride
    You can just unplug the struts, and youll get the service ride control message, but youll be fine.... its gona ride bad, but the stabilitrack wont kick in...
    You are probably doing damage by having all taht weight in the back. You might look into passive struts also.....
