Results 1 to 2 of 2
Thread: why won't my rear shocks pump up after i re[laced the alternator on my 4.9?
    Sep 2004
    49
    Arrow why won't my rear shocks pump up after i re[laced the alternator on my 4.9?
    My rear shocks were working fine until the day I changed my Battery and Alternator. Now they dont go up at all. what could be the problem? there is current going to the pump and the pump works if i connect it directly yo the batttery. what is going on? where is the fuse for this compressor?
    Feb 2005
    13
    Re: why won't my rear shocks pump up after i re[laced the alternator on my 4.9?
    Did you get help with this rear shocks problem? I have the same problem after changing out my battery. Did you find the fuse?...did that help? Would appreciate your help and return reply.
    Thanks
    Bob Elliott
    relliott7@satx.rr.com
  • You may not post replies
