I have a 93 Fleet and I just replaced the rear brake shoes and the wheel cylinders and had the drums turned. Before, none of my warning lights were on. Now, the brake light is on, the anti-lock light is on AND the traction control light is on! The brakes work fine but all these lights are on. Bled the brakes twice and I already tried to reset the computer by disconnecting the battery. Most drum brakes have a slot on the back side where you can get to the adjuster. Mine doesnt. Are they self-adjusting. And what does the traction control have to do with the brakes? When I reinstalled the adjusters I closed them all the way and the drums went back on real easy. Could the adjusters be too closed? Are you supposed to manually set them so the drum fits snug? Could this be my problem? Help, all I wanted was new brakes!
