2000 STS Rough Ride/Resistance
Results 1 to 6 of 6
Suspension, Brakes and Tires Discussion, 2000 STS Rough Ride/Resistance in Item Specific Cadillac Discussion; Hello, fellow Caddy fans... I've got a 2000 STS that I love dearly. It is my daily driver, but being ...
    JMKinney75 is offline Cadillac Owners Member
    Jan 2013
    5
    I've got a 2000 STS that I love dearly. It is my daily driver, but being 15 years old, it's getting a bit delicate.
    Lately (past few months) I've noticed a ride issue that seems to directly correspond with the wheel speed. When rolling on a smoothe, level surface, it feels (& sounds) like I'm rolling on knobby, all-terrain tires. Beyond that, the car seems to be battling some rolling resistance. It's hard to quantify, but I can tell that something is impeding my car's ability to coast freely.
    My tires are not a matching set, but they are the correct size, and I've been keeping the air pressure consistent.
    I don't believe it's a transmission issue, because the fluid is clean, not "burnt," and the issue exists even when rolling in neutral.
    It just feels like I'm riding on off-road tires. I'm a little puzzled. Due to budget constraints, I'm doing all I can to diagnose/repair as much as I can on my own.
    Has anybody else out there experienced this issue? Any thoughts?
    Thank you
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Does it sound line the tires are growling? Wheel bearings make that sound when they fail. Does the sound change as you turn at speed?
    Jan 2013
    5
    MoistCabbage, yes, it seems to diminish when turning to the right. Would that indicate a suspect bearing on the left?
    Sep 2010
    East Boston MA.
    29
    26,323
    Actually, it would point to a bearing on the (front) right. When you turn right, the weight transfers to the left, and the right bearing is unloaded.
    Jan 2013
    5
    You're correct. Maybe I'm still getting "left & right" figured out! Heh heh heh...
    I just researched swapping the hub assembly, and it doesn't look too difficult. Have you ever done it? Any tricky spots to consider?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,874
    Re: 2000 STS Rough Ride/Resistance
    Quote Originally Posted by JMKinney75 View Post
    get the car off the ground -
    hold the wheel/tire at 12:00 and 6:00 positions - (top and bottom_ -
    gently wiggle it - ANY movement at all indicates worn bearings -
    nothing "tricky" about it -
    EXCEPT that they might be rusted in place -
    be sure to only use TIMKEN or ACDELCO hubs -
    or you WILL be replacing them again - soon -
  9. Remove Advertisements
