Front end Roughness
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, Front end Roughness in Item Specific Cadillac Discussion; I have a 97 Cadillac Catera, I have replaced the lower control arm bushings because I thought that that was ...
    acecody is offline Cadillac Owners Member
    Nov 2004
    52
    Front end Roughness
    I have a 97 Cadillac Catera, I have replaced the lower control arm bushings because I thought that that was the problem, but after getting it back from the dealer it still is there. The problem is this, through the front end steering wheel, floor, pedels you can feel way too much the texture of the road, it feels like something isn't being cushioned. It should feel smooth, but it dosent when the road texture changes you can really feel it, its harsh, but it takes bumps ok so I dont think that it is struts, Please please please help!
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    Re: Front end Roughness
    This was brought up almost identically on a Seville STS not long ago. I don't think a "fix" was ever found. It sounded more like the person was just overly sensitive to the normal ride.
    Has it always felt this way to you? You might try less air in the tires. Different tires may also "fix" it.
