Proportioning Valve
Results 1 to 6 of 6
Suspension, Brakes and Tires Discussion, Proportioning Valve in Item Specific Cadillac Discussion; I lost a rotor and replaced the pads, rotor and checked everything else to be sure everything worked as expected. ...
    BenTwombly is offline Cadillac Owners Member
    Aug 2005
    7
    Proportioning Valve
    I lost a rotor and replaced the pads, rotor and checked everything else to be sure everything worked as expected. The brakes work fine on both slow easy braking and hard aggressive braking. One problem, the brake light stays on. I believe it to be the proportioning valve. I found it but I haven't a clue how to return it to the middle.
    In an attempt to balance the valve, I depressed both front caliper pistons to "reset" the fluid but the light stayed on.
    Any suggestions?
    Aug 2005
    7
    Re: Proportioning Valve
    I noticed someone wrote that the proportioning valve is LEFT to RIGHT instead of FRONT to BACK. Is this correct? If so, than if I compress the left side caliper pistons then will it reset the valve?
    What is standard procedure here. I can't imagine I need to repalce this. Please advise. Thank you.
    68
    82,056
    I am not positive but I think it is front and rear. I also do not believe that the proportioning valve will set the brake light. Check the parking brake to be sure it is all the way up in the disengaged position. Also check the brake fluid level and the level sensor.
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,661
    sometimes the sensor will get stuck, so you can try fiddling with the sensor.. pretty common problem on a lot of cars....
    Aug 2005
    7
    Dang I 'h sure feel dumb ...
    Yep, you were right, it was the sensor. While running and the brake light on I fiddled around by the break release catch ran-dumb-ly ... and the light went out. What a relief (I already had the left rear wheel off as was getting ready to depress the piston). I sprayed WD-40 all around up there. It sets and releases like a champ, and the light goes out like it should. THANKS. You guys are great. --Ben
    elwesso's Avatar
    Jan 2003
    Indiana
    7,661
    I *love* the easy problems!!! Back on my first Q45 things would often fix themselves... the self fixing car, i think thatd be a nice option to specify!
  9. Remove Advertisements
