Results 1 to 5 of 5
Thread: brakes out!
    Aug 2005
    1
    brakes out!
    hi i've got a 91 cadillac deville and the brakes went out today! the pedal goes all the way to the floor and just barely stops the car. it feels like the car pulls right and then the right front tire locks up and the car barely stops with the pedal all the way to the floor.
    if anybody can help me out with this and post back what i should do to troubleshoot it i'd really appreciate it. i don't have any money to take it to the shop cause i'm practically poor so i'll be doing any work myself.
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    Re: brakes out!
    What have you done so far? How much brake fluid is left in your master cylinder? Are there any wet areas behind you wheels? What do your pads look like?
    Get back with more info info.
    Aug 2005
    7
    Re: brakes out!
    Happened to me once. It turned out to be the brake hose that hoops near the shocks had a crack and when I depressed the brakes the fluid sprayed out.
    (1) Check fluid level (if it is low, then you likely have a leak).
    (2) Look for a wet spot somewhere/anywhere along the brake lines.
    (3) Pull each wheel and visually inspect the pads, rotors, lines.
    (4) If something looks suspicious then pull the pads (have you done that before?) and inspect further.
    (5) Check the rubber basket around the caliper piston and look for wetness, leaks.
    Let us know what you find...
  5. #4
    Aug 2005
    7
    Re: brakes out!
    There is a double piston in the master cylinder that prevents total loss of brakes in the event of fluid loss. This may be why you have some brakes that "barely stop the car".
  6. #5
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Re: brakes out!
    Yeah when I read this it makes me think of a split line somewhere along the way. Lucky for you, it shouldn't be too hard or too expensive to fix. Try and find what the definite problem is and post back
  • You may not post replies
