I need some tire help
Results 1 to 4 of 4
Suspension, Brakes and Tires Discussion, I need some tire help in Item Specific Cadillac Discussion; Alright guys, I am new to the tire and wheel category. I need some advice on choosing tires to go ...
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Alright guys, I am new to the tire and wheel category. I need some advice on choosing tires to go with the wheels:
    http://store.summitracing.com/defaul...h.asp&N=400292
    I need them to be H speed rated at least, with a load rating of a 97 or 98, and fit that 17x9 rim. I just need advice because I don't know the difference between brands, and I don't know what is meant by the Traction Rating, Temperature Rating, UTQG Tread Wear Rating, or even Tire Size.
    Thanks a lot
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Re: I need some tire help
    Well, look at the numbers on the side of your current tire (should be in the form of; P###/##R17). Really all you need to do is keep these numbers the same and keep the load rating the same or higher.
    Here's some useful tire info;
    http://auto.howstuffworks.com/tire2.htm
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Thanks for the link, but they will be different than the tires on there now becuase I am pairing them with the rims in the link above.
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    Your link renders 1500 rim options so it's no much use. Go to the Tirerack and learn everything you need to know about choosing the right tire for your eldo.
  7. Remove Advertisements
