Results 1 to 4 of 4
Thread: How to raise rear on a 93 sedandeville
    mikes93sedandeville's Avatar
    mikes93sedandeville is offline Cadillac Owners Member
    Automobile(s): 93 SedanDeville
    Feb 2005
    Richmond,Va
    40
    78
    How do you raise the rear end of a 93 sedandeville a friend told me that theirs a bar for the ride height that you just need to make longer according to the height you want. Any info would be great!
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Re: How to raise rear on a 93 sedandeville
    Attached to the axle is a small link going to the height sensor. If you adjust this, the sensor will think the car is sitting lower than it actually is and will pump up the schocks morte to compensate.
    Be advised that this could possibly shorten the life of the shocks.
    Feb 2005
    Richmond,Va
    40
    78
    Thanks ill try it saturday!
  5. #4
    addison_ii's Avatar
    addison_ii is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Sedan Deville
    Mar 2005
    Twin Cities, Minnesota
    36
    2,146
    You could also go with a passive air strut setup like I did for my 93. It receives air either thru a hose (from a gas station) or you can buy the compressor which is controlled from inside the car and raise or lower the rear on command.
  • You may not post replies
