Noise from rear
Results 1 to 10 of 10
Suspension, Brakes and Tires Discussion, Noise from rear in Item Specific Cadillac Discussion; Have a 04 cts 3.6. I've noticed over the last few weeks it's making a howling from the left rear. ...
    the_one is offline Cadillac Owners Member
    Mar 2014
    11
    Noise from rear
    Have a 04 cts 3.6. I've noticed over the last few weeks it's making a howling from the left rear. It sounds like a wheel bearing but there is no play in the bearing.
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,594
    Re: Noise from rear
    First thing I do with a howl is to rotate the tires to see if it was the tire. Bearings can howl and not show play in them. I check wheel bearing with 2 people if no obvious movement, it can be difficult if tire is flexing a little to see or feel movement unless you're under it looking whie someone moves the tire(12 and 6)
    Mar 2014
    11
    I checked the tires first. They are all good. Had the car on the lift it is tight there is no movement in the bearing and it seems to spin freely. A friend thinks it might be the cv axle but it doesn't make sense to me.
  5. #4
    rodnok01's Avatar
    Feb 2012
    NC
    6,594
    Checked or rotated the tires?
  6. #5
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    It is possible that the bearing is dry, and has no play yet.
  7. #6
    Mar 2014
    11
    I checked them. I run a tire shop there is no cupping or feathering. Tires are perfectly smooth. As far as being dry idk it's a sealed hub assembly I guess it could be possible but not sure.
  8. #7
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    50
    655
    I've replaced several noisy bearing that weren't a bit loose
  9. #8
    Mar 2014
    11
    Really? I always thought there had to be play. It's annoying
  10. #9
    Mar 2014
    11
    So I replaced the LR hub assembly and the noise is gone. There was no play but a ton of noise.
  11. #10
    rodnok01's Avatar
    Feb 2012
    NC
    6,594
    Glad you found the issue.
  12. Remove Advertisements
