How to disable the annoying light that says service ride control?
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, How to disable the annoying light that says service ride control? in Item Specific Cadillac Discussion; Hello, guys, I wanted to disable the annoying light that says service ride control. I read through the forum and ...
    getbig is offline Cadillac Owners Member
    Automobile(s): 08 ext
    Jul 2005
    Maryland
    34
    ArrowHow to disable the annoying light that says service ride control?
    Hello, guys, I wanted to disable the annoying light that says service ride control. I read through the forum and the cheapest way to do this is what Logan says on disabling strut warning (www.caddyinfo.com/disable.htm). It told me to refer to page 8a-43-6 in the 92 eldo Seville service manual.
    Where can I find this service manual? Is there a copy of just that page somebody can fax to me or pdf it? Thanks for your help again!:rolleyes2
    1 more thing, the forum discussion also mention about checking the "flashcode" Does this apply to me? I already went through the computer and came up with i039. Is that same as "flashcode"? I'm a little confuse. If there is one how can I check the flashcode?
    maydog's Avatar
    maydog is offline Cadillac Owners Fanatic
    Jan 2003
    Minnesota
    319
    Re: How to disable the annoying light that says service ride control?
    You may be able to find a cheap copy of a service manual on ebay.
