SLS ride height
Results 1 to 5 of 5
Suspension, Brakes and Tires Discussion, SLS ride height in Item Specific Cadillac Discussion; I have a 2002 Seville SLS currently with "stock" wheels/tires. I want to go 18" wheels and lower profile tires. ...
    dragon is offline Cadillac Owners Member
    Jul 2005
    1
    SLS ride height
    I have a 2002 Seville SLS currently with "stock" wheels/tires. I want to go 18" wheels and lower profile tires. What options do I have to Lower the ride height to decrease the gap between the tires and the wheel wells?
    danbuc's Avatar
    danbuc is offline Cadillac Owners Connoisseur
    Automobile(s): '87 Jeep, '10 Thruxton, '00 Duc 748, '01 748R (853cc)
    Mar 2004
    Mahwah, NJ
    32
    3,703
    Re: SLS ride height
    You should first make sure that the 18" rims and tires are th roughly the same overall diameter as the stock wheels. Going larger or smaller could potentially mess with the ABS system. Other than that, there's not much you can do other than that Eibach 1" lower spring set. You can also change the postion of the rear ride height sensors. Repositioning them 1" further up will efectively lower the rear end, but that's it. There's no real way to lower the front, without changing springs.
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Re: SLS ride height
    I also have an '02 SLS, and have tried lowering the rear abit. The rear sits about 1 1/2 - 2 inches higher than the front. I messed with the ride height sensor, and only gained 1/4" of drop. The only option is shorter springs, which are not offered for the '02s yet. Unless you get some custom made.
    Don
    98GreySTSBrad's Avatar
    98GreySTSBrad is offline Cadillac Owners Member
    Jun 2005
    38
    43
    Re: SLS ride height
    Can somebody tell me where the rear ride hight sensor is? I would like to adjust mine. Thanks
    Jamler's Avatar
    Jamler is offline Cadillac Owners Fanatic
    Automobile(s): STS
    Aug 2005
    Central Jersey
    132
    Re: SLS ride height
    You have the option to go with a higher tire...
    Not sure about yours... I"ve got an '03 and the STS tire/wheel size is 235/55/17.
    You can go with 255/45/18's. Actually the '05 STS-V comes with this size STD on Rear. (I think?). But that will fill your wheel well nicely and really improve your handling.
    Good Luck and please post pictures of whatever choice you make...
    JC
  8. Remove Advertisements
