Results 1 to 3 of 3
Thread: brake pad wear sensor
    Nov 2003
    44
    When replacing the brakes pads, does the wear pad sensor just pop in or does it need some type of glue to hold it in the u-shaped grove in the middle of the backing plate? What is the best way to remove a rounded off bleed nipple?
    Car is a 2000 STS.
    Sep 2003
    Metro ATL
    4,854
    Re: brake pad wear sensor
    The pad wear sensor is held in place by a "U" shaped spring steel clip. No glue.
    Vise grips might loosen your messed up bleeder valve. It's easier to avoid that kind of mess than to correct it. Replace the bleeder with a new OEM part after you do get it out of there.
    Nov 2003
    44
    Hello, thanks for the info. Will try with vise grips and see what happens.
  • You may not post replies
