Drilled, Slotted, Cross-Drilled, or "D" All the Above?
Results 1 to 4 of 4
Suspension, Brakes and Tires Discussion, Drilled, Slotted, Cross-Drilled, or "D" All the Above? in Item Specific Cadillac Discussion; What's the scoop on the different types of rotors and what works best on these cars? What brands are recommended ...
    RKunz2's Avatar
    RKunz2 is offline Cadillac Owners Member
    Aug 2004
    CA
    42
    QuestionDrilled, Slotted, Cross-Drilled, or "D" All the Above?
    What's the scoop on the different types of rotors and what works best on these cars? What brands are recommended (i.e. - Brembo, Pro Slot, etc.)
    I've seen cross-drilled. Slotted. And, cross-drilled and slotted. Beyond on the marketing hype and garbage, what's the real deal? Best of all worlds for heat resistance, fading, dust, and pad wear? I "hear" that slotting or drilling significantly cuts down pad life, but that's the trade-off for increased heat dissipation. True?
    I will say that I've switched to semi-ceramic vs. semi-metallic pads recently and am THRILLED with the results. Don't know about wear, but dust is 70% less than OE metallics, no noise, no squeal, no nothing. They just work!
    I've seen some varying opinions on EBC, which is not the brand I used (can't remember the brand at the moment), but the pads work great!
    Opinions anyone?
    Southern DubVille's Avatar
    Southern DubVille is offline Cadillac Owners Member
    Mar 2005
    Panama City, Florida
    37
    54
    Re: Drilled, Slotted, Cross-Drilled, or "D" All the Above?
    Hawk, Powerstop, Powerslot, Brembo and EBC are some of the brands out there, Baer makes a complete brake system but its pricey between $1000-$1500 depending on where you look. Google some of the names, I too am going to upgrade my brake system because I plan on upping the diameter of my wheels 20" or 22" but haven't make a definite choice yet. But I did find something interesting and if you are really considering slotted or cross-drilled rotors for your brake application you might want to read this: http://www.mazda6tech.com/articles/s...ut-brakes.html
    hope this helps
    DUB
    RKunz2's Avatar
    Aug 2004
    CA
    42
    Thumbs upRe: Drilled, Slotted, Cross-Drilled, or "D" All the Above?
    Thanks, DubVille. Very informative article!
    Pictures of cracked rotors really send a message.
    It sounds like it'd be best to stay with solid, but vented rotors and go with a good brand. I know Brembo supplies GM, but are they the best? I think I've got the right pad combination (although I haven't had them long enough to determine pad life), but they work very well on the car and produce little dust, noise, or squeal. The key now are the rotors.
    I really don't want to turn the fronts, so I'm looking at replacements again. Is it really taboo to replace the rotors and not the pads too, if the pads still have 50% or better remaining? Or should I just buck up the $60 bucks or so, and do it all at the same time?
    I've tried to be gentle on this set (which I hate by the way), but it doesn't seem to have mattered much. I've had cars previously that I've had to be careful with the brakes (hence, undersized systems from the mfg.) and yet, I've had other cars that it didn't matter how much you punished the brake system, it never got hurt (hence, properly sized brake system for the vehicle weight and performance). I hate that Cadillac put wimpy brakes on this thing, it really pisses me off.
    Anyway, I love the feedback, thanks again! Any other suggestions or ideas?
    bharner's Avatar
    bharner is offline Cadillac Owners Fanatic
    Dec 2003
    VA
    37
    238
    porche comes stock with cross-drilled. brembo i believe. ambulances and police use them all over the country. had them on my 98 sts b4 someone hit her. $500 bucks for all new rotors and pads all around. wow!!! have them on my 92 coupe now. wow!!!. no cracking yet. and stopping power. wow!!! PowerStop. Get those along with the posi quiet pads and you wont be disappointed.
  7. Remove Advertisements
