Factory rim offset for 98 Deville?
Results 1 to 6 of 6
Suspension, Brakes and Tires Discussion, Factory rim offset for 98 Deville? in Item Specific Cadillac Discussion; I'm planning on buying 20" rims for my car and I need advices on choosing the right tire offset, being ...
    weister42 is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville Sedan
    Feb 2005
    897
    I'm planning on buying 20" rims for my car and I need advices on choosing the right tire offset, being a FWD car it should be positive. Does anyone know the factory 16" rim's tire offset? Also what does this value change?
    Feb 2005
    897
    Re: Factory rim offset for 98 Deville?
    Anyone? I've heard of people putting 20" rims with a +35 offset with no rub.
    estyles1985's Avatar
    estyles1985 is offline Cadillac Owners Fanatic
    May 2005
    Biloxi, MS
    143
    Not sure on the offset, but I know Giovanna Barbados makes 20's for Cadillac's. You may want to call a rim shop near you to be certain, you can use the Giovanna above for reference. You also need to know the lug pattern for the deville.
    powerglide's Avatar
    powerglide is offline Cadillac Owners Connoisseur
    Sep 2003
    Hermosa Beach, CA
    2,721
    I thought it was 51 offset on the OEMs..........so you're gonna go for the dubs!
    Big_Blue's Avatar
    Big_Blue is offline Cadillac Owners Fanatic
    Automobile(s): 1986 Fleetwood Brougham D'elgance
    Feb 2005
    New Jersey
    44
    204
    This is the specs for a 1998 Devill (FWD)
    Bolt Pattern:5x115Offset Range:34 to 45Wheel Size Range:15x7.0 to 20x9.0OEM Tire Size (Front):225/60-16 (225x676 mm) Max Tire Dimensions:245x701.0
    if you tell me what rim your looking to get I can tell ya if it will fit or not with a post of the exact spec s to prove if it will or not.
    Cost of asking is Priceless!!!!!!!!!!!!!!!!!!!!!
    Cost of not knowing is your cash
    powerglide's Avatar
    Sep 2003
    Hermosa Beach, CA
    2,721
    Quote Originally Posted by Big_Blue
    Big Blue thats great info!
    I wanted to put on a set of OEM 2005-2006 STS Tires/wheel combo.
    The front are 235/45/17 and the rear are 255/45/17.
    Do you think they will fit without rubbing?
    Thanks
  9. Remove Advertisements
