rear wheel position sensors
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, rear wheel position sensors in Item Specific Cadillac Discussion; I have a code for the right rear wheel postion sensor. I disconnected the rod from both rear sensors, found ...
    tttjump is offline Cadillac Owners Member
    Nov 2003
    44
    I have a code for the right rear wheel postion sensor. I disconnected the rod from both rear sensors, found the left one to have spring tension in it, where it will go to its highest point. While the right one has no spring tension in it, it will stay wherever you move it to. Does that mean that the right one needs to be replaced? The car rides low, when I put a load in it, it rides even lower. I have notice that other STS ride high in the back. Car is a 2000 STS, no other codes are showing except for C0630.
    oldgamer's Avatar
    oldgamer is offline Cadillac Owners Enthusiast
    Feb 2004
    Staten Island, NY
    577
    Re: rear wheel position sensors
    The code says RIGHT REAR, so why bother whith a left one?
    I'm not sure about 2000 STS, but I know that right front and right rear sensors are the same, so it's easy to check what's going on by switching them. ELC use rear position sensors for height calculation, so it is possible a cause of a problem.
