'94 Deville strut spring removal
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, '94 Deville strut spring removal in Item Specific Cadillac Discussion; Can the strut spring be removed with a MacPherson spring compressor, or do I need one of the strut compressors ...
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Can the strut spring be removed with a MacPherson spring compressor, or do I need one of the strut compressors like is listed in the service manual?
    Any tricks I should know about when changing the struts?
    Thanks!
    ahanash is offline Cadillac Owners Member
    Jul 2004
    92
    Re: '94 Deville strut spring removal
    Hi:
    I did that couple of months ago, you can rent a regular spring compressor from say Autozone, but: you cannot do it without an impact wrench. the nut that is holding the strut assembly with the spring will spin with the strut rod.
    I had looked everywhere for that J socket, no where to found, I ended up putting the strut and spring back as bofore.
    So you need an impact wrench (air) and the tool that will let you hold the strut top nut from spinning with an open end to hold the strut rod. if you know what I mean.
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    I have a Mac strut spring compressor. So I'm guessing that I can just use my impact wrench to get the nut loose without using the socket tool to hold the strut shaft in place. That's good, that's what I was planning to do!
    Thanks!
