Can I repair air line for rear suspension?
Results 1 to 10 of 10
Suspension, Brakes and Tires Discussion, Can I repair air line for rear suspension? in Item Specific Cadillac Discussion; ...
    oldgamer's Avatar
    oldgamer is offline Cadillac Owners Enthusiast
    Feb 2004
    Staten Island, NY
    577
    QuestionCan I repair air line for rear suspension?
    Hi guys,
    I need some advice, so I'll start from the very beginning...sorry if it will take a bit long.
    I bought 94' STS in 1998. I noticed strange thing some time after that when I took off right rear wheel: thin air line or wire (6 years back I didn't know what is that) just hanging from somewhere.
    Couple days ago I decided to check codes and one of them was current: S038 (open circuit for exhaust valve of air compressor for electronic level control). Using trouble tree I find out that I should change exhaust valve. Manual says that in this case I should change compressor head. When I was under the car I noticed other thing too: one air line which goes from compressor to the right wheel shock was hanging and it having sleeve on the end (looks like rubber joint). And I saw other end of air line, coming from shock and hanging too. I didn't notice any joint on an air line that goes to the left shock, it was one piece. Now I think it looks like air line was cut accidentally and then rubber joint was used to fix it.
    I didn't notice anything wrong with ride or level, for some how it is fine.
    To fix a problem I need to buy whole air compressor (I didn't see anybody selling just a compressor head) and repair/change the air line too. I found used compressors on line, but always without air lines.
    So, what you think, can that air line be fixed (it should hold up to 100 PSI), should I try to buy it somewhere (I don’t even know part number and name) or I should just forget about whole thing cause car runs fine?
    Thanks for any advice.
    peteski is offline Cadillac Owners Enthusiast
    Automobile(s): 85 Eldo Biarritz
    Dec 2003
    Northeast USA
    808
    Re: Can I repair air line for rear suspension?
    I don' t think there is a good way to fix those nylon lines.
    But I had a similar problem in my 93 Eldo and I was able to buy the entire air line assy. (with all the connectors) from a local Caddy dealer. IIRC, it cost about $70 but it did the trick. You shoudl be able to buy one and just replace the broken one.
    Peteski
    oldgamer's Avatar
    Feb 2004
    Staten Island, NY
    577
    Thank you, I'll try that.
    EldoLak's Avatar
    EldoLak is offline Cadillac Owners Member
    Automobile(s): Currently Cadillacless
    May 2005
    Va Beach
    25
    I had a air ride problem on my 86' Sedan DeVille...bad lines, and what I thought was a bad compressor. I took a Rancho in-cab shock adjustment kit I had laying around and used that line to re-run the air lines from to the rear shocks. The other problem was the leveling bracket needed to be adjusted to turn on the compressor. It worked just fine for the rest of the time I owned it.
    Dec 2003
    Northeast USA
    808
    How did you do that? Caddies have special air line fittings. All aftermarket air shocks have totally different fittings. Caddy line mushrooms out at the end and that holds the o-rings in. Aftemarket shocks have sort of a compression fittings.
    Peteski
    oldgamer's Avatar
    Feb 2004
    Staten Island, NY
    577
    Last Friday I came home and found the package I ordered: used air compressor for 94 Seville. It was just $51 shipping include. I replaced the old one and installed "new". The hardest part to me was to connect air lines back to the air dryer. Fitting has clips and it should be easy, but for some reasons it wasn't. Then I took right rear wheel off and tried to fix broken air line with a rubber sleeve. I guess it's fine now, we'll see. Checked computer codes and now code S038 in a history, not a current. I feel better, couple scratches are nothing.
    Next weekend I'll take a look what's going on with RF position sensor. Code S061 bothering me more than 7 years (something intermittent).
    Dec 2003
    Northeast USA
    808
    I'm glad you got it fixed! Lets hope that the rubber hose repair holds!
    Peteski
    oldgamer's Avatar
    Feb 2004
    Staten Island, NY
    577
    Thanks. I will post what I'll find with a position sensoring. I know this is a very common trouble. For starters, yeasterday, when I went shopping with my wife, I turn computer on right after I started engine and displayed RSS data SD11, which should show data from RF position sensor. It's suppose to be in right range. And it was for the first 25-35 second of driving. Then, it suddenly jumped off the limit and stayed there. On a way back to home from parking lot it was normal again. At least it is something to think about. It's intermittent and can be wiring or sensor. What we can do without computer? It's priceless.
    Dec 2003
    Northeast USA
    808
    Yes, it is most likely bad wiring or connector.
    And comuters can sometimes be very helpful but other times a major pain in the ass!
    Peteski
    oldgamer's Avatar
    Feb 2004
    Staten Island, NY
    577
    Quote Originally Posted by peteski
    ...comuters can sometimes be ... a major pain in the ass!
    Sometimes they are, just because we get too much information. Let say, if I didn't have the computer I never knew that something wrong with suspension and never had all these worries. And car runs fine anyway. I read posting couple days ago: somebody took of the alternator to test it in the auto shop just because he has 13 something volts, less than 14. If that person has no computer he might save some money and not to do some unneeded work.
    But if something happened with computer itself it's really hard to track down. The things can go completely unpredictable.
  13. Remove Advertisements
