Rear Speed Sensors Disconnected... On Purpose?
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, Rear Speed Sensors Disconnected... On Purpose? in Item Specific Cadillac Discussion; I've recently bought a '96 Deville, and I was getting a TC0033 error. Went back, found the speed sensor connecter ...
    heugel's Avatar
    heugel is offline Cadillac Owners Member
    May 2005
    Detroit, MI
    39
    9
    I've recently bought a '96 Deville, and I was getting a TC0033 error. Went back, found the speed sensor connecter on the right rear hub was disconnected. Plugged it in, and I got a TC0037 error. So, I went back and connected the speed sensor on the left rear. Ran my codes again, clear the history, and everything reads good.
    After some cosmetic TLC, I hop in to take her down the block, and the car starts acting somewhat weird... late shifting and what not. I head back to the house, shut her down, run the codes again, and... nothing.
    So I put her through the motions - 10 miles of city driving, 30 miles on the freeway, take it back home and still no codes! In the meantime, the car's still acting weird, shifting late (from 1st to 2nd, and 3rd to 4th it seemed).
    So I stop at the nearest Autozone and run in to borrow a code-scanner. I figure maybe there's something that's not coming up on the dash that's causing the problem. Hook up the code scanner, and sure enough... no codes.
    Finally, I was frustrated, so I headed home. While speeding up on the entrance ramp, I get a Service Emissions warning, and later a PC0101 code. Checked the Mass Airflow unit, and it was clean and clear. Cleared the code, ran another 20 miles (still shifting late), and no codes.
    I'm lost now. The only 2 things I did to the car were:
    1) Plugged in the rear speed sensors, which were disconnected at the hub, and
    2) Filled up with Premium and dumped in a half-bottle of gas treatment (not injector cleaner) because the old fuel filter was pretty shotty when I changed it.
    Anyone have any clue if someone may have disconnected the rear speed sensors on purpose? If so, why? Or do I possibly have another problem (maybe as simple as dry gas disrupting the throttle control sensor system)?
    Thanks in advance for any help.
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Re: Rear Speed Sensors Disconnected... On Purpose?
    Try disconnecting it again and see if your problem goes away. Could be a bad speed sensor that someone didn't want to take care of. If your problem still persists with it disconnected then I would stop putting the addative in the gas.
    Hope you fix your problem.
