dodge 5x115 wheels on my 91 deville
Results 1 to 6 of 6
Suspension, Brakes and Tires Discussion, dodge 5x115 wheels on my 91 deville in Item Specific Cadillac Discussion; I had a set of 2012 charger wheels with tires the patterns are the same but dodge uses 14mm vs ...
    DEVIL~le's Avatar
    DEVIL~le is offline Cadillac Owners Member
    Automobile(s): 1991 Deville
    Oct 2013
    97
    I had a set of 2012 charger wheels with tires the patterns are the same but dodge uses 14mm vs GM's 12mm what are your thoughts
    My buddy gave me a set of 2012 charger wheels with great tires .I did my research they are the same bolt pattern as my Deville 5x115 but dodge used a 14mm vs the gm 12mm I did a soft mount to see how they looked and I liked them but not sure on the stud difference
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    Dodge hub bore 71.5 mm
    Caddy bore 70.3
    U need centering rings
    Are dodge rims from rwd car or awd?
    I think offset/backspacing varies
    rodnok01's Avatar
    Feb 2012
    NC
    6,722
    Re: wheel ?
    RWD. Didn't look up back spacing. I would check the stud opening in Dodge rims and see what the taper is and what lug nuts would work. Don't run without hub rings as Stoveguy has said or bad things will happen.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,180
    Re: dodge 5x115 wheels on my 91 deville
    Duplicate threads merged. Please do not multiple-post the same question in different forums - let's keep the same info and replies in the same place.
    DEVIL~le's Avatar
    Oct 2013
    97
    Sub M: I was looking for a most input as possible
    The wheels 25mm offset
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,874
    Quote Originally Posted by DEVIL~le View Post
    not gonna work -
  9. Remove Advertisements
