Front end shaking
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, Front end shaking in Item Specific Cadillac Discussion; I have a 2006 DTS 4.6 liter with approx 60,000 miles on it that when I brake on extreme downhill ...
    DanLeRoy is offline Cadillac Owners Member
    Sep 2013
    1
    Front end shaking
    I have a 2006 DTS 4.6 liter with approx 60,000 miles on it that when I brake on extreme downhill grades after approx 1 mile the front end starts shaking violently. This only happens on extreme downhills and no other time. Any advice?
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    60k miles of dragging brakes down 1 mile grades will probably wear ur rotors down. Have u inspected them lately?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,202
    Re: Front end shaking
    As written in your owner's manual, use engine braking on long downhills to reduce brake wear and the effects of temperature rise during protracted brake application situations.
    The chapter will be titled something like "Your driving and the road" - and the small advice paragraph on shifting to a lower gear when doing extended coastdown is in the types of roads section.
    Our engines shut off the fuel injectors after X seconds of extended coastdown. Injector pulse resumes as soon as the accelerator pedal is depressed slightly.
