1976 Fleetwood rear coil springs
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By 76talisman
Suspension, Brakes and Tires Discussion, 1976 Fleetwood rear coil springs in Item Specific Cadillac Discussion; Does anyone know where I can find the "correct" rear coil springs for my '76 Fleetwood? What I mean by ...
    76talisman is offline Cadillac Owners Member
    Automobile(s): 1976 Fleetwood Talisman
    Aug 2013
    1
    Does anyone know where I can find the "correct" rear coil springs for my '76 Fleetwood? What I mean by correct is that I want springs that give the right floaty, pillowy ride, like the originals. I've been told that most of the aftermarket ones available now aren't quite like the original ones - slightly tighter coil, and thus don't provide the right ride. Anyone?
    talismandave likes this.
    rodnok01's Avatar
    Feb 2012
    NC
    6,650
    If you can find the ac number and compare specs from Moog. I have found springs that fit my needs by using spring dimensions with diff spring rates.
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    Re: 1976 Fleetwood rear coil springs
    If you are still around stop up in RWD forum and say hi!
