Results 1 to 6 of 6
Thread: Wheel fit Question
    Mar 2005
    California North
    58
    5
    Question Wheel fit Question
    I have seen wheels advertised for Cadillac front wheel drives with a bolt pattern of 5 lugs with 114.3 bolt spacing. Our factory rim is 5 on 115mm. Can a guy run a 114.3 wheel? or are these advertisements wrong. .7 of a mm is mighty small???
    Anyone running a 114.3 on their car?
    Mike c.
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Re: Wheel fit Question
    I have read a post somewhere, that most aftermarket wheel manufacturers, do not make the two different sizes. It stated that if you ordered 115 mm lug pattern, you will actually receive 114.3 mm. As you stated, .7 mm is quite a tiny number. Hell, a full mm isn't too much to worry about. As long as the hub diameter, and the offset is correct, you will not have a problem.
    Don
    Sep 2004
    Finland
    19
    Iīve heard that in Europe they use/say 114.3mm...the same anyway. No problem.
  5. #4
    Sep 2004
    Finland
    19
    Sorry for my wrong answer (the previous one). I got different wheels and they didnīt fit 100%. Vibration occured. Have to drill the holes more wider.
  6. #5
    timothyr's Avatar
    timothyr is offline Cadillac Owners Fanatic
    Automobile(s): 78 FWB d'Elegance, 92 deVille, 93 Seville, 06 DTS
    Mar 2004
    Arizona
    465
    to further complicate this question, and not to hijack the thread...i am looking at putting new wheels on my 93 seville, and i see alot of people saying that the rims are interchangeable between the CTS, 05 STS, and the 86-04 FWD cad's...I thought the offset would be different for the FWD vs RWD cars...am i missing something?
  7. #6
    Jun 2005
    11
    93 sts: i put some 17" x 7.5" :115x5 bolt patern 40mm offset, they fit perfect. try the tirerack.com, good selection. I mounted 245/45 tires... awesome!! Add some eibach springs up front(not on the rear) for the look!!
  • You may not post replies
