99 'Lade pulls to the right
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, 99 'Lade pulls to the right in Item Specific Cadillac Discussion; I have a 99 Escalade that pulls to the right, requiring slight pressure on the steering wheel. I had the ...
    ohenry is offline Cadillac Owners Member
    Sep 2003
    Medford OR
    65
    5
    Question99 'Lade pulls to the right
    I have a 99 Escalade that pulls to the right, requiring slight pressure on the steering wheel. I had the front end aligned and there was no change. Assuming the alignment was done correctly, what other issues should I look at as the cause?
    BUILDINGCTSAMG is offline Cadillac Owners Connoisseur
    Mar 2003
    Atlanta Ga/Mclean Va
    32
    1,753
    Re: 99 'Lade pulls to the right
    Without a doubt wheels, if you bought aftermarket rims or whatever thats ur first thing to look at, also important is the tire, cheap tires will pull,its a simple fact....even if u have nice rims and nice tires if they werent mounted perfectly ull get some pull....
    cadfan is offline Cadillac Owners Member
    Sep 2003
    47
    Quote Originally Posted by ohenry
    Swap the frt tires to see if the pull goes the other way. If it does- tires are your problem. 99 Esc. are known for their pull.
