Problem removing stabilizer link from front strut
Results 1 to 6 of 6
Suspension, Brakes and Tires Discussion, Problem removing stabilizer link from front strut in Item Specific Cadillac Discussion; Is there any trick to removing the stabilizer link from the front strut? I have tried pushing, pulling, hammering, pressing... ...
    shrike2000 is offline Cadillac Owners Member
    May 2004
    Texas
    48
    21
    Is there any trick to removing the stabilizer link from the front strut? I have tried pushing, pulling, hammering, pressing... all of the "ings" basically. I put a c-clamp on there and tried to squeeze it out. Nothing seems to be working. I'm putting liberal amounts of WD-40 on there in the hopes that it penetrates that connection and loosens it up. I know there's not much there holding it on, it must just be rusted or something. But, just in case I'm missing something, let me know if there's a special technique.
    Snowman's Avatar
    Snowman is offline Cadillac Owners Member
    Automobile(s): 93 Seville SLS
    Nov 2003
    Ontario Canada
    43
    Re: Problem removing stabilizer link from front strut
    I replaced the passenger side one on my 93. If they are the same ??, simply undid the nut and it popped out, I had the car jacked up, and then put another jack below the lower control arm to make sure there was no force on the link.The link I removed an Allen key socket in the end of the threaded bolt, I just used vice grips on the booted knuckle to stop it from turning while removing the nut. The new Moog stabilizer link had a shoulder cut in the boss for a wrench to but used on. I don't know if a 97 is the same as a 93. Good luck.
    maydog's Avatar
    maydog is offline Cadillac Owners Fanatic
    Jan 2003
    Minnesota
    319
    You can use a second jack to unload the pressure of the joint. I had a lot of trouble myself, I tried a torch to heat it up, and air hammer and the c clamp. Ultimately I had to cut a wedge out of the hole to get the link to let go. I have some pictures on my site http://maydog.dyndns.org/www/struts/...e_replace.html , it was a pain in the A.
    Snowman's Avatar
    Nov 2003
    Ontario Canada
    43
    Quote Originally Posted by maydog
    I think I'll change the Drivers side one very soon and put some antiseize on it. My SLS came from Texas, and no rusted parts, but now that its being driven in Ontario, it won't take long for the "rusties" to get it.
    Murphyg's Avatar
    Murphyg is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 STS
    Oct 2003
    Ontario
    1,575
    Attempted to do the passenger side on my 93.
    Looked easy enough.............NOT !
    What a pain !
    Good thing I didnt cross the point of no return. Ended up takin it to the shop. Was a bit of a strugle for them at first. Then they brought out the big guns.
    That sucker was seized on real good. And that was the end that was the easiest to get too.
    BTW...WD sucks.
    Try using a penetrator called Moovit made by Lloyds. Does everything WD does but better. And its non solvent.
    oldcady is offline Cadillac Owners Member
    Automobile(s): 1996 Eldorado
    Dec 2013
    1
    Hope to be helpful: has had the same trouble and used a 27016 Pitman Arm Puller with a socket on the nut of the stabilizer link to protect the thread. It said after very heavy pushing "pop" and I could proceed.
  9. Remove Advertisements
