which rotors and brakes should I get? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Suspension, Brakes and Tires Discussion, which rotors and brakes should I get? in Item Specific Cadillac Discussion; For every site you find that says they don't warp, there is one that says they do. http://www.r1concepts.com/blog/are-y...ing-or-warped/ Cast iron ...
  1. #16
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    50
    655
    Cast iron skillets warp, cast iron cylinder heads warp. Cast iron rotors warp. Like I said before, go ahead and keep telling people they don't warp, and I'll keep fixing the ones that are.
  2. #17
    Douglas Rome is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-4 3.0 sedan black/black
    Aug 2013
    Elburn IL
    70
    283
    Re: which rotors and brakes should I get?
    Earl, you can't change anyone's mind you may as well caulk it up. I'm a
    backyard mechanic and have done many brake jobs on my personal cars
    over the years. I must say it got a whole lot easier since the advent of disc
    brakes. What I do is only replace the rotors if they are causing vibes or
    they are scored bad. I don't turn them either, just replace the pads. One time
    I tried expensive pads, if I remember EBC's, what a mistake, not only did they
    cost too much but they were terrible dusting and wore out faster and a total
    waste of time and money. I'm not a race car driver, just an average old man
    putzer, don't need anything but OEM, they last longest and stay cleanest and
    make less noise. That's why these engineers make the big bucks. thanks, douglas
  3. #18
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,518
    Curious - I use EBC slotted rotors and Redstuff ceramic pads and have excellent braking with NO dust. 2 years now and the pads are hardly worn. Pictures in my albums. (I gotcha by 6 years)
  4. #19
    Caddy-EaRL's Avatar
    Apr 2013
    Ky
    50
    655
    Next time I need pads ima try out the redstuff. I have akebono's for two years now and they are still about 70% left. No dust at all, seems to stop about like ac delco's. Sub, what kind of difference to you feel with the slotted rotors?
  5. #20
    Feb 2006
    55,518
    Hard one, Earl ............ I went straight from the stock GM rotors/pads to the EBC Black Dash Ultimax (whew!!!) slotted rotors and Redstuff pads. After a wild day of breakin 2 years ago, they're great brakes.
    The reason I did the change was speed-related: I run the car occasionally on public days at Dover raceway and an old airport road (farm border) over in east MD. At the airport you run out of pavement and have to make a hard right turn at 6,000 feet - just over a mile. The stock brakes would literally disappear by the time you dropped from 130+ to ~40 - one time ! With the slotted rotors (and I think it's not just the slots - the ventilation vanes are better) - I still have plenty of brake on the side road. At Dover, two pretty severe slowdowns from 100+ would make the stock brakes "slippery" - no such sensation with the slotted rotors - same reasoning as above.
    Coming down from speed you can hear the slots - a kind of low-pitched background 'whirrrrrrrrrrrrrrr.......', but it's not loud.
    Best part: The braking action is glass-smooth............... and essentially zero dust (after breakin).
  6. #21
    Caddy-EaRL's Avatar
    Apr 2013
    Ky
    50
    655
    Hmmm interesting, thanks for the info.
  7. #22
    CTSCHICK Guest
    Got a set of EBC Ultimax rotors and red stuff pad's coming for my CTS same setup I used on my last car with no issue's
  8. #23
    Feb 2006
    55,518
    For those that DO go with EBC pads and rotors ........... The pads come with a smear of EBC's "Brake-In" compound on the face of the material. It's a hard, slightly abrasive coating that wears away quickly and smoothes the rotors as well as assures there aren't and pad resin deposits left from old pads or, in the case of the Ultimax rotors, the black zinc coating is polished off the braking surfaces. During the break-in period these pads can be scary - the noise and vibration may be just awful for the first few hard stops. Follow the recommended break-in procedure - I did mine in one afternoon, worried a lot, and am now a happy camper; someone who is not used to working with high performance brakes may well have second thoughts and be scared, especially if the break-in has to occur in a city driving environment.
  9. #24
    CTSCHICK Guest
    The paper work that comes with the EBC's does state most of that
  10. Remove Advertisements
