How do you remove the Tri-Pot housing from transaxle?
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, How do you remove the Tri-Pot housing from transaxle? in Item Specific Cadillac Discussion; I'm replacing the inner CV joint boot, drivers side. I have the half-shaft out, but am not sure how to ...
    eyewonder is offline Cadillac Owners Fanatic
    Automobile(s): 2000 STS, 200K Miles
    Nov 2011
    SE Kansas
    68
    187
    I'm replacing the inner CV joint boot, drivers side. I have the half-shaft out, but am not sure how to get the Tri-Pot housing out. The FSM shows some sort of clamp(?) that goes around the housing, & a slide hammer arrangement to pull it out. It sounds like it just pulls out (no hidden snap rings, etc) with a little force.
    Here is where I'm at now:
    But I don't want to break anything, so anyone have experience getting these things out? As always, help is appreciated.
    Cheers,
    Steve
    Nov 2011
    SE Kansas
    68
    187
    Re: How do you remove the Tri-Pot housing from transaxle?
    Got it. Wrapped some small chain around the transaxle end, put a nut/screw thru the links to keep it tight, pry bar under the opposite side, then used a big weight as a slide-hammer to pull it out. It came out after a few whacks, with no damage to case.
    Cheers,
    Steve
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,241
    A pinch bar behind it against the trans case will get it too.
