Wide tires
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, Wide tires in Item Specific Cadillac Discussion; '08 CTS I'm want to put wider tires on my CTS. The tires currently are stock 18s. I'd like to ...
    Caddy Kim is offline Cadillac Owners Member
    Automobile(s): 2008 CTS4
    Jul 2012
    Western Massachusetts
    7
    Wide tires
    '08 CTS I'm want to put wider tires on my CTS. The tires currently are stock 18s. I'd like to go wide enough that they are just inside the wheel. Anyone know what will fit without having to replace my rims?
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    Re: Wide tires
    how much clearance do you have from tire to inner fender? a wider tire could rub on outer edge by fender lip and also rub on inside edge next to strut or spring. the tire works with the rim specs. rim width and offset. a different rim can move tire in or out. i can say i have rim so and so but if you cannot find it at your local wheel shop than that does you no good. you need to go to shop and work with tech to achieve your goal.
    Jul 2012
    7
    Thanks I will do that.
