Seville SLS ride height
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, Seville SLS ride height in Item Specific Cadillac Discussion; Is the rear ride height adjustable? The back of my car seems to be too high. Is thier an adjustment, ...
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Is the rear ride height adjustable? The back of my car seems to be too high. Is thier an adjustment, that would make the rear of the car lower to the ground, and have the auto adjust shocks, adjust to the new height? Thanks for any input.
    Don
    90devilleguy's Avatar
    90devilleguy is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 STS-V & 1962 Coupe Deville
    Nov 2003
    Framingham,Ma
    548
    Re: Seville SLS ride height
    There is a way to adjust the sensor's arm in the back of the car underneath. I will find the insturctions tonite on my alldata software....i might try doing it to dude cause these cars look bad with the suspension up so hight compared to the front.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,129
    Not bad for a 5 year old thread !!!
    The ELC is set to carry the car with about a 1/2" to 1" forward rake and the arm length is not adjustable, but there is some sort of a ride height adjustment setting with a Scan-II (GM dealer diagnostic/programming) electronic tool. For the 2002 it's called a "Bump stop learn" procedure.
    If your rear suspension is obviously too high, then you need to use the car's factory built-in code reader/scanner system to determine if any Diagnostic Trouble Codes are set. That will tell you if you have ELC compressor (exhaust valve) or shock absorber problems.
