Wire wheel cover advice needed!
Results 1 to 4 of 4
Suspension, Brakes and Tires Discussion, Wire wheel cover advice needed! in Item Specific Cadillac Discussion; Well, I got a great deal on five wire wheel covers for my '88 Eldorado. They are in pretty decent ...
    sprocket is offline Cadillac Owners Member
    Automobile(s): '88 Eldorado
    Apr 2010
    MN
    53
    97
    Well, I got a great deal on five wire wheel covers for my '88 Eldorado. They are in pretty decent shape. Never since I owned the car has it had hubcaps of any kind. It instead had alloy rims off a '96 Deville.
    I decided to return it to stock and bought used 14" steel rims with tires included. Then I bought the wheel covers. Of course, they came without the locks or a locking tool. This is not a problem for me because I am a machinist and if I can't find locks I can just make them. It would help if I had even ONE so I don't have to reverse engineer too much.
    The center hole on the wheel cover is threaded and takes a special wrench to turn the movable part that the threaded hole goes through. I've never seen a wire wheel lock up close but there must be a threaded stud that you screw the wheel cover to with the special wrench.
    So here's the question:
    If I'm making the wheel locks anyway, can't I just put a threaded hole in the lock and then attach the wheel cover with a bolt that is small enough to fit through the existing threaded hole? I understand this makes them easier to steal, but maybe I could use torx screws.
    Sound reasonable?
    Apr 2010
    MN
    53
    97
    Re: Wire wheel cover advice needed!
    Well no responses, but I managed to get two on the car. I found bracket cones at the junkyard but they were the wrong ones. They stuck out way too far. I solved this issue by beating the hell out of them. Now they sit low enough. Beating them broke the nut plate out of the center, but that turned out to be a good thing. I replaced that with an 8mm nut that was tapped into a 1/2 washer. this was then wedged into the hole that was left from the nut plate. I then screwed an 8mm button head allen bolt into the rotating nut in the hubcap. I was then able to screw the hubcap onto the cone. I thought I was done but the center cap wouldn't snap on. The head on the allen bolt stuck up too high. I solved this problem by removing the allen bolt and using a hand grinder to shorten the rotating nut. I then screwed the allen bolt back into the nut and reinstalled the hubcap. Then the center cap snapped into place. The rest is history.
    If this sounds like a lot of screwing around, it is, but I refused to give up. I still have two more to go.
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    i think GM used dozens of different styles and heights... last two I tried swapping around were a freaking nightmare. Post a pic or two
    Apr 2010
    MN
    53
    97
    Quote Originally Posted by rodnok01 View Post
    Sure. I'll have them off tomorrow because the car is going in for an alignment and to have the tires balanced. I bought the tires used and I can tell they're off a bit. I'm not going to expect the tire guy to figure out how to get the wheel covers off. The brackets are ugly but you don't see them and they WORK.
  7. Remove Advertisements
