Wheel backspacing on 1994 Fleetwood
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, Wheel backspacing on 1994 Fleetwood in Item Specific Cadillac Discussion; hey guys i have a '94 fleetwood and was looking to install so 22s, the wheels in question are +38mm ...
    chevydyl is offline Cadillac Owners Member
    Automobile(s): 94 Fleetwood
    Nov 2010
    31
    4
    hey guys i have a '94 fleetwood and was looking to install so 22s, the wheels in question are +38mm offset they are also 9.5 inches wide, what offset to do i need to have to obtain correct fitment, i was going to use adapters/spacers to make them work, i have read that the fleetwood uses a -10 +10 offset, so if i used a 1inch spacer which is about 25mm that would bring the wheels to a +13mm offset correct? and would that be enough? i can get the wheels for a super good deal so i would really like to make them work any help with wheels sizes from 20s to 22s and the maximum width backspacing would be helpful thanks
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Re: Wheel backspacing on 1994 Fleetwood
    Spacers are always a bad Idea. With 22's that need a 1 inch spacer, there is no correct fitment.
    www.tirerack.com would have a wheel fitment calulator.
