Wheel bore
Results 1 to 5 of 5
Suspension, Brakes and Tires Discussion, Wheel bore in Item Specific Cadillac Discussion; Found some nice cheap chrysler 300c rims. They have 71.5 bore or slightly larger than my 70.3 on my 96 ...
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    Wheel bore
    Found some nice cheap chrysler 300c rims. They have 71.5 bore or slightly larger than my 70.3 on my 96 Sts. Chrysler rims also have slightly bigger bolt holes 14mm vs 12mm on gm but tapered seat lug nuts should fix that. Will I need centering rings? Do they sell them?
    Aug 2007
    mpls mn
    2,527
    Re: Wheel bore
    I could make some simple sleeves from tubing for the studs. 14mm OD x 12mm ID. That would help the lug centering which may not be a big deal. I have a lathe. I could even make some centering rings. I found a few websites that sell them. They will be 0.6 mm thick which is real thin and flimsy. Probably will be easy to bend. A larger bore wheel will fit on a smaller hub, not the reverse. The offset and backing spacing are real close and I am using stock width tires so it should be ok.
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Re: Wheel bore
    This is a bad Idea. Are the lug tapers different?
    You have 6 points of fitment problems & if the lug taper angle differs they won't seat for very long before loosening
    rodnok01's Avatar
    Feb 2012
    NC
    6,719
    Re: Wheel bore
    If you could find hub sleeve maybe they would work, since the hub carries the weight. matching the angle on nuts would be critical. You need to make sure the rims sit perfectly flat against the hubs also. I think I would pass on this myself...
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,123
    Re: Wheel bore
  8. Remove Advertisements
