2001 DeVille rear uppper control arm replace
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, 2001 DeVille rear uppper control arm replace in Item Specific Cadillac Discussion; I have been searching for the procedure to replace the rear upper control arm on my base model DeVille. http://www.rockauto.com/catalog/moreinfo.php?pk=2783466 ...
    jlc
    jlc is offline Cadillac Owners Member
    Feb 2005
    1
    My concern is the mounting bolts toward the center of the vehicle. There doesn't seem to be enough space to get the bolt out so I began searching for a how to and have been unable to find any instructions. It almost appears that I need to loosen the rear suspension sub frame from the body and lift the body up away from the sub frame to get the needed room. If anyone knows the procedure I would appreciate the help.
    Thanks,
    Jeff
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,630
    Re: 2001 DeVille rear uppper control arm replace
    For the 2002 Seville the entire rear suspension sub frame needs to be lowered, along with the entire exhaust system. Bummer.
