Shake Shimmy STS - Page 5
Page 5 of 17 FirstFirst 123456789101112131415 ... LastLast
Results 61 to 75 of 253
Like Tree1Likes
Suspension, Brakes and Tires Discussion, Shake Shimmy STS in Item Specific Cadillac Discussion; The 2000 and latter Deville suffers the same vibration problem as the 1998 and latter Sevilles. I think both share ...
  1. #61
    Logandiagnostic's Avatar
    Logandiagnostic is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS, 2005 Mustang GT, 2010 MINI S
    Feb 2003
    Franklin, TN
    1,118
    ExclamationRe: Shake Shimmy STS
    I think both share the same cradle, strut, and engine mount style. I think both share the same exact problem.
    Logan Diagnostic
    www.ledfix.com
    www.airbagcrash.com
    www.logandieselusa.com
  2. #62
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    50
    2,817
    Quote Originally Posted by Logandiagnostic
    Logan Diagnostic
    www.ledfix.com
    www.airbagcrash.com
    Alright, that kills that idea. I was hoping this was the breakthrough we needed. Oh well. I still haven't checked my cradle bushings yet. But, it is supposed to be fairly nice on Saturday. I will check them out, and see what I find.
    Don
  3. #63
    Feb 2003
    Franklin, TN
    1,118
    Don- I'm confused...I think this is the breakthru.....
    I think the cradle mounts and the strut mounts are too loose on both cars. I think this causes the whole front end to jiggle on anything but perfect road.
    I think both of our cars.....your Seville....my Deville.....share the same front end design.
    Many Deville owners on other Cadillac sites complain of the exact same vibration as Seville owners. The dreaded 60-75 mph vibe.
    The temporary sockets clamped in between the cradle and body.....and the stiffened upper strut bushings.....has removed 90% of the issue on my Deville.
    Logan Diagnostic
    www.ledfix.com
    www.airbagcrash.com
  5. #64
    iametarq's Avatar
    iametarq is offline Cadillac Owners Connoisseur
    Automobile(s): 98 Deville, '15 Ford Fusion Hybrid Titanium, '12 Ford Escape
    Dec 2004
    Petoskey, MI
    36
    3,294
    Sorry Logan, I'm going to have to re-read this thread from the beginning. i'm too tired at the moment though.
  6. #65
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    The new DTS has a new engine/trans mount set-up where they added a dogbone to the upper right side of the engine. It's to keep the engine from moving around and to take some of the load off the front oil-filled engine mount, which tended to rip. Also, the front control arms were totally redesigned and beefed up over the old ones. From what I've heard, the engineers felt those two things contributed to the vibration problem.
  7. #66
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    50
    2,817
    Well, decided to check out the cradle mounts today. They all seemed to be in good condition. I noticed that they are made of a rather soft rubber. I would think that a hard rubber, or polyurethane, would be a better choice. Anyway, since they seemed alright (no movement), I decided to check the torque on them. All but one (there are six), needed at least a little tightening. The two rears were pretty loose. They both required about 1/4 - 1/2 turn. The others were about 1/8 turn. I have not yet driven it yet, but after I do (probably Monday), I will see if this had any affect.
    Don
  8. #67
    Incogneatto is offline Cadillac Owners Member
    Jan 2005
    17
    i waiting to know the answer to this 1 because i have the same problem with my '02 deville. i too thought it was an alignment problem so i got the car realigned about 400 miles ago. before i drove the car off the lot the dealer tried to say that i would always have a little vibration problem because of the aftermarket wheels i have one the car.... which i knew was untrue b/c i had the problem before i changed the rims and tires. after reading this and seeing that people have the same problem, i think he was just putting the problem off on my rims. it has gotten bad again and i plain on getting it realigned again (becuase it does help) but i will tell him to check the engine mounts for tightness. although i feel like my frontend is out of line now and needs to be fixed the culprit has changed from a set of new rims and tires to a design flaw.
  9. #68
    Feb 2003
    Franklin, TN
    1,118
    Dcadillac....yes the rubber is very soft.
    Now....once you understand how the cradle mount works....you will see the rubber problem.
    The upper mount plate has a sleeve that surrounds the mount bolt.....the sleeve travels down thru the rubber......the lower plate bottoms out (upward) on this sleeve.
    So if the rubber decays....it does.... the mount cannot be tighten any further.
    You could go 100 foot pounds over tourque and the mount will not be any tighter....
    I have attached a paint shop pic. Here is the code:
    Maroon: Car body
    Black: Cradle
    Red: Upper mount (note sleeve around bolt)
    Blue: Lower mount plate
    Yellow: Rubber
    Pink: Cradle bolt
  10. #69
    Feb 2003
    Franklin, TN
    1,118
    The Red upper....and blue lower cannot be tightened and closer due to the red tube mount. Blue bottoms out on red....
    As for firmness of the mounts....you need a bigger screwdriver or pry bar. Try hooking the large screwdriver into the cradle...then hit it hard....that cradle is dancing all over the place. Vibration.....
    Then think.....how would this cradle react on a not so perfect road at 70 mph?
    Logan Diagnostic
    ledfix.com
    airbagcrash.com
    logandieselusa.com
  11. #70
    grogan is offline Cadillac Owners Member
    6
    Cadillac still shaking 10,000 miles later. Dealer replaced tires two more times, load force balance 5 more times, replaced front end buhings replaced tie rod end. Contacted Cadillac customer care, they offered me a $2500 coupon on a new GM car, is this anyway to deal with a problem they cannot fix. I was given an extended warranty to cover the front end. The shimmy/shake problem has never been resolved. Has Cadillac resolved this problem for anybody. Are these cars safe to drive with the shimmy/shake? Cadillac has refused to put into writing that my car is safe to drive!
  12. #71
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    50
    2,817
    Quote Originally Posted by grogan
    Do you really fear for your life while driving your car? If so, sell it, and get something else. The shimmy I am accustomed to, is not dangerous. Just an annoyance. If you are experiencing a violent shimmy, causing you major concern, than you do not have the 60-75 mph shimmy. What you have is major problems.
    Don
  13. #72
    El Dobro's Avatar
    Sep 2003
    1,471
    GM's been using 6 mount cradles on Caddys since 1985 and I don't ever remember having any shaking problems until they eliminated the dogbone mounts.
    One of the guys one the board changed the front engine mount to a racing mount and remarked how smooth everything was. That's the mount that always tears and leaks oil. Maybe if there's a solid rubber mount available frm an auto parts store, maybe the OEM on should be changed to see if there's a difference.
  14. #73
    agood1 is offline Cadillac Owners Member
    Mar 2005
    83
    What about new cradle mounts...does anyone make replacements...maybe in a stiffer polyurethane?
  15. #74
    Feb 2003
    Franklin, TN
    1,118
    There are some solid Fiero monuts available.....but I dont think they will work on the Deville....
    So far....thats all I have found....
    Go wiggle the cradle....I think you will be shocked.
    What would that cradle do.....at 70 mph on a cruddy road.
    Logan Diagnostic
    www.ledfix.com
    www.airbagcrash.com
  16. #75
    hardrockcamaro@mac.c's Avatar
    hardrockcamaro@mac.c is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Oct 2005
    40
    1,339
    At 65-70 my 2000 Seville is ok.
    My problem is at lower speeds, say 40-60.
    Could it also be the cradle (damn car only has 19K on teh clock!)?
  17. Remove Advertisements
