Shake Shimmy STS - Page 12
Page 12 of 17 FirstFirst ... 234567891011121314151617 LastLast
Results 166 to 180 of 253
Like Tree1Likes
Suspension, Brakes and Tires Discussion, Shake Shimmy STS in Item Specific Cadillac Discussion; Originally Posted by Dadillac After driving yesterday and today, the shimmy is still present. The hub change has done wonders ...
  1. #166
    tstach is offline Cadillac Owners Fanatic
    Automobile(s): 2001 BMW M5 - Alpine White
    Jul 2003
    Hebron, KY
    52
    226
    Re: Shake Shimmy STS
    Quote Originally Posted by Dadillac
    After driving yesterday and today, the shimmy is still present. The hub change has done wonders at improving the situation, and it has been diminished quite a bit.
    What about the rear hubs? Do you think they may need to be replaced?
  2. #167
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Quote Originally Posted by tstach
    Way ahead of you. I checked them yesterday, by doing the one hand high, one hand low, wiggle test. They seem to be fine. The strange thing is that the shimmy has lessened, but not changed. If that makes sense. I am guessing ball joints. I will do another wiggle test on the fronts, and see what happens. I hope it isn't ball joints. Getting those rivots out will be a nightmare. I guess that will give me a reason to buy the angle grinder that I have always wanted though.
    Don
  3. #168
    Red-October is offline Cadillac Owners Member
    Apr 2006
    3
    Thumbs upRe: Shake Shimmy STS
    Hey All,
    I just got my car back from Cadilliac. They tested my hubs and it turns out the rear passenger hub was a little off versus the rest of the car. They replaced it and the vibration is 99% gone. Every now and then I feel it a little bit and the passenger seat shakes a tad but it's as good as it's going to get. The master tech at this dealership says that because of the stiffer suspension, i'm going to feel EVERYTHING on the road. Anyways, I'm very happy with the car overall. There's a lot of annoying little things that are still waiting to be fixed but I hope that once they're taken care of, that's it. When I get the actual service printout, I'll post exactly what they did to my car. Good luck and I hope this was helpful.
    John
  5. #169
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Well I think I damaged the passenger side axle shaft while removing the hub. I am getting a terrible metal squeak whenever the shaft is moving in and out. I know this will not be cheap, and may be a PITA. I have never changed a CV before, so it will be a new experience. Will it ever end?
    Don
  6. #170
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Since the shimmy hasn't completely disappeared, I ordered rear hubs today. The part number is 812003, and got the pair on Ebay for $240.60. I will post with results.
    Don
  7. #171
    Apr 2006
    3
    CoolRe: Shake Shimmy STS
    I fixed the vibration 100%. It turns out that one of my tires was inflated at 24 while the rest were at 30. I reinflated the tire and there's no vibration at all. Combined with a hub bearing and a hub being replaced, the car drives like a dream.
    John
  8. #172
    Free Willie's Avatar
    Free Willie is offline Cadillac Owners Member
    Automobile(s): 2000 SLS (totaled by deer) 2003 DTS 63 Fleetwood
    Mar 2006
    Connecticut
    52
    4
    Hey Dadillac, I've been following this thread with great interest as I have the same issue on my 2000 SLS. I also buy alot off Ebay but I can't seem to find the hubs, shocks or stuts like you have. What are you searching under or using for keywords?
    I am currently recovering from shoulder surgery so I havn't been able to experiment with yours and Logandiagnostics ideas yet but I would like to start gathering parts so any info would be apprieciated. Thanks
  9. #173
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Quote Originally Posted by Free Willie
    When searching a part number in Ebay, you need to click the title and description box. Otherwise, it just searches titles. As far as shocks and struts, you need to be patient, and check Ebay everyday. Items like the hubs are there all the time. Good luck with your recovery. I go in for my knee on May 1st. That is why I am trying to get as much as I can done now. Because it isn't going to be easy, or smart, to do anything during my recovery.
    Don
  10. #174
    Logandiagnostic's Avatar
    Logandiagnostic is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS, 2005 Mustang GT, 2010 MINI S
    Feb 2003
    Franklin, TN
    1,121
    ExclamationRe: Shake Shimmy STS
    Ok.....this may be it......
    Been having a problem with the front axle. 6 months ago tried to replace....but could not get the hub out of trans.
    Yesterday, had new axle and axle shaft puller here. Got the axle snub out of trans. Snub has very strange wear. (see pic)
    I think in this car the trans shaft bushing is gone. The bad news is this bushing is not available.....you have to buy the complete case extension..... plus select washers etc....mess...
    So the new axle is in. It was a slightly different part. Noticably heavier on the transmission side.
    Now the vibe is worse with the heavier part....ahhhh.....clue.
    Got this theroy from another post on net....
    "The bearing/bushing/case in the trans axle, where the axle enters, was worn and the axle was loose.
    At high speeds the axle would bow out at the inner CV joint (run in an elliptical fashion).
    This whipping effect caused the vibration."
    I think this is exactly whats going on. Please note the damaged bearing surface on the snub.
    I can pry on the axle snub and it moves.
  11. #175
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Okay, here is what I have done already. After the list of parts, the shimmy is still there, although not as bad.
    Front outer tie rod ends
    Four sets on tires
    Three sets of wheels
    Front struts
    Rear shocks
    Road force balance
    All four brake rotors
    Brake pads
    Adjusted tire pressure
    Strut tower brace
    All four hub assemblies
    Front motor mount
    Installed spacer in engine cradle mounts, to clamp cradle tighter to the car
    I am sure that I am missing something that I have done. But so far, all of these had an overall little effect on the issue. I spoke of retro fitting dog bones onto the car earlier. I will be trying this next. Unless Logan can give positive feedback to his tranny/axle situation. I just wish it was legal in NJ to drive without a hood. I would remove it, and see how much the engine is moving at speed. I also wish I had one os those small wireless video cameras. I could see what it is doing then also. Maybe I will just cut a huge hole in the floorpan, and watch it through there. But when I do the dogbones (providing I can get them to fit), I will update the thread.
    Don
  12. #176
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    The only things missing in your list are the updated control arms.
  13. #177
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Quote Originally Posted by El Dobro
    Relentless aren't we?
    Don
  14. #178
    PeteSTS is offline Cadillac Owners Member
    Dec 2004
    DesPlaines,IL
    20
    My buddy put the new control arms on his 1999 STS with no change,he said it was a waste of money.
  15. #179
    Dooman's Avatar
    Dooman is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Black and Tan STS
    Mar 2004
    753
    Quote Originally Posted by PeteSTS
    Funny, that's the exact way my wife feels about our 99.. "waste of money"
    Oh! You meant just the control arms...
  16. #180
    ohioplayer77 is offline Cadillac Owners Member
    Jan 2006
    went throw the same thing you did! 2001 sts 17 in rims. i found the fix, thought about calling caddy and selling it to them. dealer also told me it was a bad rim regarding the offset design or the rim. anyway here is what i did. luckily i used to work at a local service station and had access to a tire balancer. i removed all the tires on the car. removed all the weights that were on the rim, and spun each one. i took the roundest two tires and saved them for the front of the car, the least round for the back. i then balanced each tire in the static mode (that means you just put the weight on the inside of the rim.) after the tire balanced out perfect in static mode, i then balanced it in normal mode (that means you put weight on inside and outside of rim.) without removing the previous weight i put on in static mode. after i got a perfect balance in normal mode i went back to static, again without removing any weight put on so far. i did this back and forth till i got a perfect balance in normal and static modes. You will do this from 2 to 4 times a tire, and also have weights spreed all over the rim. some directly across from each other, you may be tempted to remove some weights as you go. DO NOT. i tried everything and this really WORKS. sounds crazy and long, but IT WILL WORK! and save you time in the long run
  17. Remove Advertisements
