99 concours brakes squealing!!
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, 99 concours brakes squealing!! in Item Specific Cadillac Discussion; So my 99 deville concours is making a lot of squeaking/ squealy noises which only go away when i step ...
    concours99 is offline Cadillac Owners Member
    Automobile(s): 1999 Deville Concours
    Oct 2011
    33
    1
    Exclamation99 concours brakes squealing!!
    So my 99 deville concours is making a lot of squeaking/ squealy noises which only go away when i step on the brakes. The noise is coming from the back, looked at the pads, they don't look that bad but i could be wrong. Anyways willing to change the pads if it will get rid of the annoying noise. Are the pads for the concours, same as the ones for the deville or the sts of the same year? Also willing to change them at home, anything to watch out for?
    Thanks in advance,
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,619
    Re: 99 concours brakes squealing!!
    The caliper lower bolt comes out, the caliper swings on the upper bolt/pin and slides off. The piston DOES NOT press back into the rear calipers - it screws in and must be aligned with the indents in the face of the new pads - part of the parking brake self-adjustment system.
    If your brakes are squealing it's either excessively worn pads, bad rotors, or both.
    Somebody else - Does this car have pad wear sensors ?? ..........and if it does, I wonder if they have been bypassed.
    concours99, Talk to Chris in Parts at Rippy Cadillac over there >>>>>>>
    69
    82,188
    Not sure if it has electrical wear sensors (don't think so), but the squealing is from the mechanical wear indicator tab rubbing on the rotor. Changing pads will cure it.
