Strut Piston Comes Off - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Suspension, Brakes and Tires Discussion, Strut Piston Comes Off in Item Specific Cadillac Discussion; Thats a reasonable plan. You will know if there is unequal dampening, it can be a scary out of control ...
  1. #16
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Re: Strut Piston Comes Off
    You will know if there is unequal dampening, it can be a scary out of control feeling but seeing the car has only 28,000mi it may be ok.
  2. #17
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,186
    Quote Originally Posted by asilverblazer View Post
    I am replacing it with a new Magnaride strut, I just can't afford to both right now. I'll see how it goes once I get the new one to determine how quickly I replace the other side.
    When you are finished with the job, inflate the tires to 34 psi, COLD, and do a test drive: On your way to the rural country roads, check the front end dive and stability. Does the nose drop evenly upon aggressive braking ?? Does it rise evenly upon aggressive acceleration ? Out in the boonies, find a straight stretch of road that will allow you to do a long series of shallow S-turns at about 35 - 40 mph. Does each front corner dive the same amount from right to left turns ? You should be able to make RADICAL changes in direction (S-turns) with very little nosedive, body roll, or any sensation of loss of control. As the car senses that you are in an aggressive driving mode the suspension should tighten further until the road and steering feedback is pretty intense. If you really get carried away, the transmission will enter PAS (Performance Algorithm Shifting) mode in which you are, in effect, driving a foot-shifted manual transmission. If you're willing to experiment, the F55 cars are capable of maneuvering and handling that the F45 series can only dream about.
  3. Remove Advertisements
