brake problems
Results 1 to 5 of 5
Suspension, Brakes and Tires Discussion, brake problems in Item Specific Cadillac Discussion; bought a 73 eldo, owner put new pads and rotors on front. now front brakes do not work. anyone know ...
    bill henry is offline Cadillac Owners Member
    Automobile(s): 1962 sedan deville
    Feb 2011
    horseshoe lake,arkansas
    70
    25
    brake problems
    bought a 73 eldo, owner put new pads and rotors on front. now front brakes do not work. anyone know what the problem might be.
    69
    82,262
    Re: brake problems
    Describe "do not work". Is the pedal hard? Does it go to the floor? Are there any leaks? Is the reservoir full?
    Feb 2011
    70
    25
    Re: brake problems
    reservoir is half full. filled it up, brakes work some what. stoped the car. hissing sound coming from under hood when applying brakes. looks like some kind of leak down front of the booster.
    69
    82,262
    Re: brake problems
    Sounds like the master cylinder.
    Feb 2011
    70
    25
    Re: brake problems
    thanks for the info. will check out m/c this weekend.
  8. Remove Advertisements
